Passenger Side Floorboard Moisture
This is a discussion on Passenger Side Floorboard Moisture within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; Finally got the opportunity to clean out the truck today (35 degrees) and get to the passenger side and observe moisture (full water droplets). Scratch ...
Results 1 to 10 of 11
Like Tree6Likes
Thread: Passenger Side Floorboard Moisture
    Ecoboost Regular Dworth's Avatar
    Ohio
    147
    14856
    63 times
    Finally got the opportunity to clean out the truck today (35 degrees) and get to the passenger side and observe moisture (full water droplets). Scratch lung my head I lift up my floor board mat and it is soaked. Take the mat out of the truck and take a further look and observe what looks like mold growing underneath the glove box toward the front of the truck. Touch the fireproofing and it is soaked. I wipe everything up and move along to washing the the exterior. After washing the exterior the light bulb went off and thought I would check the passenger side. Lift up the mat and had water spots all underneath again.
    Have anyone experienced this before and have any starting points? Next step would be to sit in truck and have someone else hit it with the hose. However, that will be a couple days. I have heard of 3rd brake light, windshield, or area through the fender which requires removal.
    Truck is a 2018 STX SCREW. I hardly have anyone in the passenger seat so I am thankful for the vinyl. I would have never caught it I had carpet.
    2013 Ford F-150 Lariat Ecoboost. Max Tow Package w/ 6.5 foot bed.
    Rookie grizzlypower2001's Avatar
    58650
    Welcome to the indoor water feature club. Do you have the pano sunroof?
    Sent from my XT1710-02 using Tapatalk
    4,073
    3263 times
    Quote Originally Posted by grizzlypower2001 View Post
    Can you get that with the STX trim?
    Whatever it is, that's definitely a warranty job there.
    Ohio
    147
    14856
    63 times
    No, Sir. It is an XL with STX package. I had a sunroof on my 2013 Lariat and it leaked so I got a bare bones truck for less things to break and it still leaks. Assuming this has been leaking for a while and the thought that my family has been breathing this mold is irritating.
    Ohio
    147
    14856
    63 times
    Warranty job for sure. I just like to try to fix it myself if possible because I am the type I do not like anyone touching my truck. Having them driving it through their car wash makes my skin crawl with my black paint.
    Wanted to see if anyone else had the the problem or have it act as a PSA for others to check their carpets after it rains.
    Eco-Beast Chris H's Avatar
    Rowlett, TX
    2,768
    5338
    2527 times
    I have the same issue but on the diver's side - my emergency brake handle was holding water after the last deluge. My truck recently underwent an 11-month full repaint so I called my body shop and he said it's most likely either the windshield seal leaking or one of the sunroof drains is clogged. I'm going to take it back to him, probably next week, to see what he can figure out.
    2011 F150 Platinum screw 2WD 6.5' bed, 3.73 Max Tow pkg | Full Race FMIC | EPP catted downpipe | PowerStop Extreme | OEM Harley front end | Belltech 3/4 drop | Black Rhino Traverse 22" | built motor & EFR's coming soon...
    2018 Ford Transit XLT 12 passenger van 3.5 EB | stock for now...
    1992 Mustang 5.0 coupe bolt-on play thing.
    1964 1/2 Mustang Indy 500 Pace Car - OEM replica, collector car toy
    Ecoboost Regular JoeKool315's Avatar
    Jan 2019
    Lugoff, SC
    120
    69580
    40 times
    Quote Originally Posted by Dworth View Post
    Don't touch it!
    under warranty, their going to have to replace all the padding carpet/vinyl in your case and most likely a harness or 2 if it's got water damage in the connectors. If you start digging into it, they could very well try and pin the leak on something you "did" during your digging around. Absolutely take it in to the dealer ASAP. start a trail as quickly as you can on this. mold growing shows it's been happening for a while so tell them the same thing. You hardly have anyone in the passenger side and just noticed it after cleaning up the interior. Any service manager worth their salt is going to jump on this quick and get you taken care of.
    Good luck bud!
    Purefection, milesej05 and Dworth like this.
    2017 SCREW 3.5L XLT FX4 3.31 Locker w/302pkg Ruby Red/Magnetic Metallic
    Roush intake, tune, exhaust, floormats
    Carhartt F&R seat covers
    JLT pass. side catch can
    Tailgate "easy down" strut
    7,634
    3325 times
    Next warm day you have, take your truck to a self car wash and have another person spray near the door edge to windshield part of the truck as well as your windshield cowl while you videotape the passenger side seat. That will help diagnose where the issue is coming from and will help you out at the dealership.
    As @JoeKool315 mentioned, do NOT try and mess with it at all.
    Dworth likes this.
    Ohio
    147
    14856
    63 times
    Quote Originally Posted by JoeKool315 View Post
    Don't touch it!
    Good luck bud!
    Good advice. Did some snooping today with visual inspection and it appears that it may be at the windshield where the rubber / plastic piece lays. In the center of the windshield it seems to overlap and that is one area that is lifted and another small area near the passenger side. As miles mentioned below, I am going to water test it and take a video.
    Truck goes in on Thursday and I will update afterwards.
    58650
    I would start a log of events, document everything. Everything you found, pics, conversations, times of calls and people's names. I have a leaker, with 5 trips to the dealership (all within a few months) from leaks in different locations. End result, my sunroof still leaks, but it drains to the outside of the vehicle now.
    Dworth likes this.
  1. Turbo Moisture
    By Robt in forum F150 Ecoboost Performance
    Last Post: 05-22-2014, 05:37 PM
  2. Intercooler moisture
    By Soleary in forum F150 Ecoboost Chat
    Last Post: 03-22-2014, 08:17 PM
  3. Moisture in my head light...
    By waldo in forum F150 Ecoboost Maintenance
    Last Post: 03-18-2014, 11:02 PM
  4. Moisture in fog after hid install
    By Boostnf150 in forum F150 Ecoboost Appearance
    Last Post: 01-26-2014, 12:45 PM
  5. taillight moisture?
    By scdeputydawg in forum F150 Ecoboost Problems
    Last Post: 01-03-2014, 09:46 PM
