Horrible fuel mileage - Page 3
This is a discussion on Horrible fuel mileage within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; Originally Posted by Steven Thompson I do know my speedo is off, when going 70, GPS on phone says i'm going 75. Then your mileage ...
Results 21 to 30 of 37
Like Tree30Likes
Thread: Horrible fuel mileage
    495
    122 times
    Quote Originally Posted by Steven Thompson View Post
    Then your mileage likely isn't as bad as what your inaccurate readout is giving you. Worry less about the MPG, and more about keeping your speed in check. A tuner is a way to fix this from what I been reading. I've considered it myself.
    Puyallup, WA
    908
    4854
    405 times
    Well, that's your problem if you are just looking at the computer for your mpg's... You are essentially logging LESS miles than you are actually traveling, so the computer is only telling you what it sees.
    Even if you hand calculate and take the odo miles, it's still lower than actual miles driven, so there you go...
    You gotta fix the the odo to get the correct miles driven.
    I had to do that with my 97 F150 when I got taller tires.. That truck was so old, I only had to swap out a speedo gear... After 1999, it's all computer controlled..
    Mitch
    Rookie Steven Thompson's Avatar
    7
    70650
    So with dealing with current MPG, what would be first step in upgrades to improve MPG. Tune? And if so any recommendations?
    4,055
    3133 times
    Take a look at this. It's got some info and suggestions towards your question.
    https://www.f150ecoboost.net/forum/1...challenge.html
    495
    122 times
    Even if you got a tuner, kept the stock tune, and just changed your tire size on the tuner you'd see an increase on your display. It'd then be accurate. I cant say as for tunes on effect on mpg. That's a different topic. There is probably some reading on the site as for info on that.
    7
    70650
    I would really like my computer to read more accurately, any suggestions on tuner to change tire size and also ease of use.
    Oc
    647
    4453
    234 times
    Hate to break it to you, but your right foot and slowing down are the best mpg mod (other than ditching the tall, wide, heavy tires). There is no mod on the market where the $ amount in fuel savings will ever be more than the initial price of the product. Drive it, enjoy it, or get a fuel efficient vehicle...
    if if you want a tune for more power and better drive ability, then go for it, but don’t be surprised if you get worse mpg’s.
    1,029
    363 times
    Best step for MPG is go to stock tire size in a highway tire. No AT or MT. Just a nice highway tire. The best tune for MPG is Ford stock tuning and staying out of boost.
    Gearhead Tuned
    Wagner CAC - Accel Copper Plugs
    Bilstein 5100's
    3,406
    2875 times
    I think you mentioned you have a 2012?
    There's currently a "tuner" for sale on here that can calibrate for tire size easily enough. However, I'm pretty sure it is only compatible with 2017+?
    Hopefully the fellas with Gen1 3.5's will know more about that?
    Rookie F150Rusher's Avatar
    Aug 2016
    Idaho
    18897
    Big tires, bad gear ratio, maybe a lift too, if you do alot of 15 min or less driving, winter blend gas, all put the MPG of these trucks in the ****ter. Yea it looks cool and all, but you live with the 13mpg.
    Thanks for the laugh though. It's been a week (uncharacteristically) or so since the last time someone posted a strikingly similar thread.
    For the OP: Don't worry, most of us have taken their turn in this particular fish barrel. Be sure to search for older threads, this has been a frequent topic. Some go short, some go long and detailed...but the info is there. If you want to search for some of my posts with my username, you'll find a few of my posts and they're probably worth reading for newer truck owners. I went through the learning curve, too.
    Fundamentally, it's all about the trade-offs. Truck Designers and Engineers are great people...but they aren't magicians (well, some think they are). The Laws of Physics and Thermodynamic are real and must be dealt with. Electronics have enabled a LOT of improvement, getting us all a lot closer to the "ideal" efficiencies...but we're never going to exceed the fundamental limits. That's what has pushed Ford into aluminum bodies and beds -- steel is just too heavy.
    One thing I don't see frequently, is the tip to "reset the CAM." It's the memory module that, among other things, records details of your operating conditions, driving practices and tendencies, etc. In theory, your primary ECM module uses this data to automatically optimize your gas mileage, among other things. In practice, the data can get corrupted, thus GIGO. Two, maybe three years ago, my mileage was really sucking...and the Service Manager at my servicing dealership suggested resetting (clearing) the CAM memory. Tried it...for about 10 days only a slight improvement. Fortunately, it then started improving, pulling me up into the 16-17.5 range round-about our semi-rural town, 18-19 highway at 70 mpg.
    >>>>> Be aware, most Service Managers won't have any idea what the CAM is...they simply aren't into the technical electronics of the vehicle. If not, ask to have their truck electronics guy speak to you, he'll translate for you back to the SM
    MPG goes up dramatically if I keep speeds to 60 or below. I can easily get over 22 mpg highway if I do that. However, my time also has value, so for me I pay the extra fuel costs and save time.
    Cruise Control is far superior to your foot for improving MPG. I don't know why, it just is. Using cruise as often as you can, even in-town, will up your mileage a bit, at least for the longer hops.
    Another short tip: plan your trips so your engine gets properly warmed up. Short hops KILL the 3.5's MPG. And if you're in a really cold clime, don't plan on getting more than perhaps 14.5-15 MPG during the winter.
    Be sure you're comparing apples to similar apples. 2011 thru 2014 eco-boosts are good vehicles and engines...but Ford improved the engines over time. One of my buds has a 2018 with better gear ratios than the 3.73 (though I forget exactly what his ratio is), a 3.5 engine, and a 10 speed transmission. He can get into the mid-20s driving highway trips at 70-75. My 2011 3.5 EB with only modest upgrades will never achieve that, that's the plain truth.
    Few years back I put on a K&N Air Filter and got immediate MPG gains...about 2 mpg!! However, I gave that back when I put on my hefty brush guard and a high-rise bed cover (Snug-Top, with extra insulation to boot). But you can probably gain a bit with a K&N or similar after-market air filter. Many state that adding larger exhaust tubes & free-flowing muffler also ups the mileage...but if you read the threads thoroughly, not everyone actually sees that improved MPG. Why or why not, I don't know -- but if you go that route, make sure you can live with the resulting increased noise from the exhaust.
    Lots of people also go for tuners and custom tunes -- those aren't for me. I want to keep the electronics mostly stock.
    Personally, I'm extraordinarily happy with my 2011 F150 EB SCREW -- it's quite simply the best vehicle I've ever owned. But when I put on my desired options...something had to give...and MPG was the penalty paid.
    Best of luck!
    Jim
    rpenn57 and Mikedick77 like this.
  1. Real world F150 Ecoboost Fuel Mileage
    Last Post: 05-17-2019, 10:52 PM
  2. Horrible MPG 2013 FX4
    By Av8er36 in forum F150 Ecoboost Problems
    Last Post: 10-30-2018, 11:22 PM
  3. New to the Eco Boost and getting horrible mileage
    By Jasebring in forum F150 Ecoboost Problems
    Last Post: 12-31-2015, 09:40 PM
  4. would I buy UPR again? Unsure, the support is horrible
    By Srlaubach in forum F150 Ecoboost Accessories
    Last Post: 11-09-2014, 08:43 AM
