Any Ecoboosts without problems? - Page 2
This is a discussion on Any Ecoboosts without problems? within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; 2012 Platinum with 180,XXX miles on it, it had 130,XXX when I bought it. In the almost 2 years I've owned it: A/C control module ...
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 76
Like Tree28Likes
Thread: Any Ecoboosts without problems?
    Ecoboost Sr Member JIMS12PLAT's Avatar
    Georgetown Tx
    90
    37122
    37 times
    A/C control module stuck on defrost (replaced entire a/c module in dash)
    Oxygen Sensor failed (replaced)
    LF wheel hub vacuum?? failed (replaced wheel hub)
    RR wheel cylinder leaked (replaced wheel cylinder)
    Back up camera quit working, haven't replaced yet.
    All normal maintenance done as required. I had full service records from the selling dealer when I bought it.
    *Random rattle at start up that's been there for over a year.
    Ecoboost Jr Member jpodraza's Avatar
    Nov 2018
    Buffalo NY
    22
    68760
    At least a few folks here have success stories. The truck was great until about 50K when the engine became suspect. The other issues were more of an annoyance and they were seemingly fixed well. Its frustrating that an engine with 50K has to be stripped down is supposedly fixed and the problem returns. I don't tow and I haul mainly garden stuff 2-3 times a year,
    compost manure etc,
    and the giant pumpkins I grow that are 1500-2K#.
    If teh V8 is more reliable I think id be fine with it.
    Eco-Beast EcoXLT's Avatar
    1,776
    6645
    864 times
    Mine has been so good that I’ve never even took the engine cover off yet. 48k on odometer.
    Ecoboost Pro Lizardking419's Avatar
    MN
    552
    3795
    193 times
    Well, from everything I have read. The 2018 V8's are different than the 2011-2017 V8's and the new motors like to eat oil.
    I have a 2013 with 63,000. Bad HPFP around 20,000. Bad lead frame not long after. Had a catch can on for 50,000 miles and took it off thinking I was going to trade it in but did not.
    I've had a bad multi-switch and my in tank fuel pump had issues but I replaced both and have not had a problem with either since.
    Luck of the draw. It's a crap shoot.
    Sent from my moto g(6) using Tapatalk
    4,556
    1664 times
    Absolutely don't go with a 2018+ F150 5.0 if you're looking for reliability, it's not going so go so far.
    I feel ya though, my old 2013 3.5 ecoboost was a POS, my 2017 2.7 was great but only got to put about 17,500 miles on it because it was a lease to get me out of that old 2013.
    I now have a 2019 f150 3.5 and only have 575 miles but so far so good lol
    Other than the thumping sound thats coming from the engine or transmission area at low RPMs light throttle... Same sound my old 2013 3.5 had
    4,009
    1142 times
    2014 45k, zero issues. Intercooler and catchcan will ensure your eco runs perfect, along with normal maintenance.
    v8's have problems, like the fuse that can fail and leave you stranded unless you mod it so it doesn't.
    Also, OP your issues are not mechanical that are going to leave you stranded with exception of the rear end. You make it sound liek dealer broke something...no idea what a snap reverse is.
    494
    122 times
    Mine had a few issues when I got it. I fixed it myself and didn't let the dealership touch it. I also would never get rid of mine for a V8. Some have issues. You fix them with common sense, patience, and a little green. Maybe you go look at the 2.7's like has been mentioned above, maybe you go with a V8.
    Stock, Weep hole, 160 degree T-Stat, Autolite Iridium XP5863 gapped properly, Mobil 1 full synthetic 5w-20, and 93 octane
    Nov 2018
    Buffalo NY
    22
    68760
    "Also, OP your issues are not mechanical that are going to leave you stranded with exception of the rear end. You make it sound liek dealer broke something...no idea what a snap reverse is."
    well that is what they told me. The snap on reverse was a well documented issue that some thought was the slip yolk but wasn't. There was a TSB that put a spacer in the rear diff and adjusted the pinion for this. When I picked it up after the rebuild the tech and service advisor told me it was the result of the TSB not being done correctly and something in the diff was overtightened....Just what I was told
    Ecoboost Veteran BAD454SS's Avatar
    HELL Arizona
    344
    14381
    140 times
    Just turned 30,000 on my 14 , only been to dealer for master cylinder recall. i change plugs every 10,000 and oil every 2500 swap air filters at oil change also. Runs really strong , i run it very hard couple times a week but mostly putt back and forth to work at the speed limit . I am starting to have issue with rear camera. So far been a good truck .
    2014 FX4Tremor,FullraceDP,Wagner,BBK,Afe CAI,ITV22,MSDcoils,180 thrmostat ,Unleashed 91 tune.
    2010 Raptor ,6.2L, 2.9 Whipple 650 hp kit .MODS everything
    2002 Lightning ,3.4 whipple ,800 RWHP, MODS everything
    1993 454 SS ,502 ci and 2.4 kennebell, 600 rwhp MODS everything
    1979 10th annivesary trans am 400 4spd , 56,000 orig miles, Stock
    1963 Impala 21,000 orig miles
    2015 POLARIS Scrambler 1000,Stock
    1995 BANSHEE ,Not Stock
    1985 Yamaha RZ500 ,4 cylinder2 stroke,12,000 miles , Australia
    Ecoboost Sr Member {tpc}'s Avatar
    Aug 2018
    Berkley, MI
    74
    66606
    16 times
    I've only had my '18 2.7 for a little less than a year, but its doing well. I've had some minor issues/annoyances along the way, but it happens.
    2018 Magnetic F150 XLT SuperCrew 2.7l Ecoboost/302A
  1. Replies: 22
    Last Post: 05-08-2017, 07:40 AM
  2. Is anyone having any Issue's or problems with the 2.7 TT so far???
    By blakeman62 in forum F150 Ecoboost Problems
    Last Post: 04-21-2016, 01:27 PM
  3. Problems, Problems, Problems
    By silvercreek in forum F150 Ecoboost Problems
    Last Post: 06-28-2015, 09:04 AM
  4. Any one else have constant livewie ts/sct problems
    By 13XLTSC in forum F150 Ecoboost Performance
    Last Post: 10-30-2014, 12:40 AM
  5. Anybody had any problems?
    By Dam Electrician in forum F150 Ecoboost Chat
    Last Post: 10-01-2013, 09:10 PM
