Again with the misfire! - Page 2
This is a discussion on Again with the misfire! within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; also try simple as unhooking the battery over night. Let it relearn idle in morning for 10min and driving easy until coolant temp fully up ...
Results 11 to 16 of 16
Thread: Again with the misfire!
    4,124
    1190 times
    also try simple as unhooking the battery over night. Let it relearn idle in morning for 10min and driving easy until coolant temp fully up for a bit.
    Rookie Drewbley's Avatar
    May 2018
    12
    63162
    p0302 cylinder 2 misfire
    p054a
    Cold Start Exhaust 'B' Camshaft Position Timing Over-Advanced Bank 1
    p054c
    Cold Start Exhaust 'B' Camshaft Position Timing Over-Advanced Bank 2
    May 2018
    12
    63162
    thanks ill try that
    4,124
    1190 times
    So cam sensor cold start is not misfire, that is cold start I am assuming lol and it cannot adjust desired? I would research that more, that could be related to the timing issues, especially with you having 12. Do you have the chain noise on cold start?
    3,046
    1078 times
    This. Makes me think timing chain.
    511
    127 times
    Quote Originally Posted by Drewbley View Post
    Plugs in, hole drilled.
    Codes are back again p0302 p054c p054a.......
    Starting to lose faith in ford
    So.... Plugs in hole drilled.... It's been like 2 1/2 months since your first post. Has it worked for 2 1/2 months and now it has codes and no misfire?
  1. Replies: 15
    Last Post: 06-08-2016, 01:26 AM
  2. Low Oil Pressure Warning again and again
    By Sherr20 in forum F150 Ecoboost Problems
    Last Post: 04-05-2016, 05:58 PM
  3. OMG, did I screw up again?
    By 737jet in forum F150 Ecoboost Problems
    Last Post: 07-25-2014, 03:48 PM
  4. it shines again!!
    By cnrwbaker in forum F150 Ecoboost Photos/Videos
    Last Post: 09-18-2013, 11:11 AM
  5. Replies: 8
    Last Post: 07-14-2013, 07:35 AM
