Csp 19n01 - Page 2
Csp 19n01
This is a discussion on Csp 19n01 within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; If you combine both the software patch AND the extended coverage together, and I think that's not a stretch, Ford is addressing this issue. While ...
Results 11 to 20 of 20
Like Tree11Likes
Thread: Csp 19n01
    3,368
    2865 times
    While it took them long enough, I commend them for stepping up.
    I'm not painting them as saints. It took a lot of unhappy customers to get this far, but it's a solution that IS customer beneficial.
    Elmore328 and Mikedick77 like this.
    Ecoboost Veteran djfllmn's Avatar
    PA
    446
    66244
    198 times
    My understanding is the new programming just allows for more misreads/nonreads from the sensor before making the decision to downshift. Are you saying if the sensor no longer works, the new program can distinguish a failed sensor vs. just being at a stop?
    correct
    2018 2.7 Supercab XLT sport Lightning blue
    1968 Thunderbird
    Past: 16 F150 5.0 , 14 F150 5.0, 07 F150 5.4, 03 Ranger 4.0
    Master Certified Ford parts and warranty administrator
    4,055
    3133 times
    This is the most current picture of @snakebitten that I can find!!!! But he looks exactly like this EVERY day.
    494
    122 times
    And this would be a correct take on the subject. I'd rather they did something like this than acting like it's not happening at all. This is a step in the right direction.
    Stock, Weep hole, 160 degree T-Stat, Autolite Iridium XP5863 gapped properly, Mobil 1 full synthetic 5w-20, and 93 octane
    771
    239 times
    Quote Originally Posted by djfllmn View Post
    correct
    Then yes, I agree Ford did step up to the plate here. This was the missing component for those that have had the issue - replace the part if the codes show it failed. I'll have to get my truck in sooner than later.
    ARE Z-Series topper w/Yakima rack, Bilstein 5100's, StopTech Sport brakes, BFG T/A KO2 on stock rims, RXP Catch can w/UPR check valves, FR Gen 2 Radiator, Saudi Trans cooler, CR Performance Engineering exhaust manifolds, Rear blocks removed, Firestone Air bags.
    Rookie birdmfc's Avatar
    Paducah, KY
    3614
    This actually happened to me this morning, I got the yellow wrench, truck missed out, then odometer went to 0. I am checking with the dealer now to make sure I can get this to be warranty fix.
    4,009
    1142 times
    everyone is so obsessed with the turbos when the motor and fuel system can't handle anything lol
    3,368
    2865 times
    Good point
    Rookie SergeantV's Avatar
    May 2019
    71542
    I got this recall notice three days after changing my transmission. I had gotten the recall and fluid change my transmission started to slip and I got the orange wrench light and codes for the output speed sensor. Now I'm down $3,400. I'll call Ford tomorrow but I'm sure they will reimburse me $0. Too little too late because I handled it on my own.
    3,843
    1711 times
    this just hit last night for you 2011-2013 guys
    Just got my Canadian notice today, truck was built in March 2013.
    Says it's good for 10 years or 240k Kms (whichever comes first). If vehicle has already exceeded mileage limitation, then it's good until November 30, 2019.
    Also waiting on the follow up recall notice for the 1st gear downshift issue.
    I've had NO issues so far. Just under 110k Kms on truck.
2013 f150 molded leadframe
f150 19n01 service
ford 19n01
