Jiffy tite connector torque specifications Help! - Page 2
This is a discussion on Jiffy tite connector torque specifications Help! within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; Yea I know how it is. Still owe on mine also, but still someone else'e abuse on it we inherited I suspect. Same deal here ...
Results 11 to 15 of 15
Like Tree6Likes
Thread: Jiffy tite connector torque specifications Help!
    497
    122 times
    Yea I know how it is. Still owe on mine also, but still someone else'e abuse on it we inherited I suspect. Same deal here on getting it running right. Im glad I chased down all that KS stuff, holes in EBOV's, weep holes, getting anal on spark plugs and oil changes. It is what it is. I dont tow or anything but i'm not about to go back to driving cars now.
    Ecoboost Jr Member torchred's Avatar
    Canada
    33
    15698
    You should put the torque specs in your first post if you don't mind so people don't have to come hunting through all of this thread plus the one you linked.
    780
    243 times
    Good Suggestion. Done.
    Ecoboost Master 2016BoostedGreyGoose's Avatar
    Florida
    1,400
    15467
    643 times
    I did this on my 2016. I didnt remove the AC compressor or both belts...I only removed the belt that goes around the idler and the alternator. Was tougher NOT removing the AC, but overall I am glad I didnt.... In the 1st pic you can just barely see the AC compressor in the lower right side.
Size:  3.43 MBName:  20190215_215322.jpg
Size:  3.95 MBName:  20190216_114255.jpg
    Blown F-150 and DNA Dan like this.
    780
    243 times
    Nice! That looks like there's more room at the firewall than there is on my 2012. I only pulled the AC because I changed that oil and coolant inlet pipe connector. Surprisingly the oil screen was really clean.
  1. Dudes! Help me out. Need to know what this connector is called.
    By winchested in forum F150 Ecoboost Lighting
    Last Post: 02-27-2019, 04:58 AM
  2. Spark plug connector broken
    By Jordy in forum F150 Ecoboost Problems
    Last Post: 07-05-2018, 09:38 AM
  3. Help with reverse light connector
    By TN11BlackXLT in forum F150 Ecoboost Lighting
    Last Post: 02-11-2015, 05:04 PM
  4. Ignition Coil Connector Part Number HERE!
    By winchested in forum F150 Ecoboost Maintenance
    Last Post: 06-16-2014, 07:50 PM
  5. 2013 Dimensions and Specifications
    By madmaxmutt in forum F150 Ecoboost Chat
    Last Post: 04-03-2014, 02:30 PM
