2013 F-150 3.5L ecoboost hissing under mild acceleration
This is a discussion on 2013 F-150 3.5L ecoboost hissing under mild acceleration within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; My F-150 3.5L eco now has 51,000 miles on it. I donít know if itís something I just never noticed before since I bought this ...
  • 1 Post By Mikedick77
Thread: 2013 F-150 3.5L ecoboost hissing under mild acceleration
    Rookie Slbynum's Avatar
    Apr 2019
    71140
    My F-150 3.5L eco now has 51,000 miles on it. I donít know if itís something I just never noticed before since I bought this truck used at 43000 miles but I have a slight hissing noise that only occurs under very mild acceleration. Cruising around 35 or 45 miles an hour if I give it just the slightest amount of acceleration I hear this hissing noise but if I continue my acceleration the hissing noise goes away as I accelerate more beyond mild acceleration. Itís not super loud inside the cab and I canít hear it with the window down with all the wind noise or if the radio is on. Any idea what this could be?
    Steve
    497
    122 times
    Might pop off your blow off valve from the intercooler and take a look at the orange diaphragm inside the valve. I had this issue, and replacing that part fixed it, and also netted me a little bump in everyday performance.
    Apr 2019
    71140
    Well I finally got it down to the Ford dealer and left it with them and they said the noise was normal. When I went down to pick it up I had him drive with me and he heard the slight hissing noise which goes away when I accelerate further and he said it was normal.
    780
    243 times
    I believe that's called BOOST!!
    497
    122 times
    I've heard the same in mine before I fixed the BoV. It went away. Sounds like a stream of air hitting the pavement, right? It's not a noise i'd think was normal. Especially when it went away after my repair. Might be something to ponder.
  1. 2013 ecoboost whining noise under acceleration
    By Twenty13ecoboost in forum F150 Ecoboost Problems
    Last Post: 04-07-2019, 04:49 PM
  2. Sounds like a hissing noise.
    By Michaelh in forum F150 Ecoboost Problems
    Last Post: 06-29-2018, 01:05 PM
  3. 2016 3.5L Ecoboost shudder under light acceleration 45mph+
    By 2016BoostedGreyGoose in forum F150 Ecoboost Problems
    Last Post: 06-17-2016, 10:08 PM
  4. Hissing Noise on Passenger Side of Engine Compartment
    By defiant1 in forum F150 Ecoboost Problems
    Last Post: 12-26-2015, 03:43 PM
  5. boost leak/hissing sound with afe intercooler installed
    By vic_s197 in forum F150 Ecoboost Performance
    Last Post: 08-04-2015, 08:22 AM
