Whine at any speed
Whine at any speed
This is a discussion on Whine at any speed within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; So I got a 2014 f150 and am getting a grinding whine from what sounds like the driveline the sound increases with speed coasting or ...
  • 1 Post By Butch1124
Thread: Whine at any speed
    Rookie Butch1124's Avatar
    Apr 2019
    71160
    Whine at any speed
    So I got a 2014 f150 and am getting a grinding whine from what sounds like the driveline the sound increases with speed coasting or on the gas dont change it ...I have put new u joints in took the rear diff cover off and looked at the pinion it looks to be good no more slop that it should checked transfer case fluid and still cant pin point the source......I also want to mention it is the same in 4x4 or 2wheel drive ...I took the drivline off at the end of my dirt driveway and drove it to the house in 4 wheel drive without the driveline installed and no noise ...so could it be a bent or out of balance drivline ? Sorry for the long post and thanks in advance for suggestions..
    497
    122 times
    Check the brakes, wheel bearings?
    Apr 2019
    71160
    I had the rear tires off with brakes off and still.made the noise and with the rear drivline off and I drove it the noise was gone so wheel bearing should be good ...
    497
    122 times
    If it didn't make the noise with the driveshaft off and in 4wd only using the FWD, then yes, i'd suspect the driveshaft, since the rear wheels had to be turning, process of elimination. And that's if i'm understanding correctly what you've done to eliminate the noise.
    Apr 2019
    71160
    Yes that is what I did I am going to balance my drivline this week thanks
  1. 60mph whine
    By bammons88 in forum F150 Ecoboost Problems
    Last Post: 12-15-2018, 06:12 AM
  2. 2013 fx4 whine during off gas pedal
    By Brewman in forum F150 Ecoboost Problems
    Last Post: 08-14-2018, 10:04 AM
  3. 17 Raptor gear "whine" while coasting
    By Srlaubach in forum Ford Raptor Ecoboost
    Last Post: 08-28-2017, 04:12 AM
  4. 2011 3.5 eb, no boost/constant whine, started with weird noises
    By Ryjonesy91 in forum F150 Ecoboost Problems
    Last Post: 03-04-2016, 10:17 AM
  5. Gear Whine Coming from Rear Diff?
    By tbird462002 in forum F150 Ecoboost Problems
    Last Post: 12-20-2014, 01:30 AM
