2013 F150 Ecoboost surging
This is a discussion on 2013 F150 Ecoboost surging within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; Hi, 2013 Ecoboost is surging, during idle it’s shaking the truck slightly, but when I’m driving down the road it feels like it’s surging, rpm ...
Results 1 to 10 of 14
Like Tree4Likes
Thread: 2013 F150 Ecoboost surging
    Gold Supporting Member Vrooom's Avatar
    Apr 2019
    13
    71098
    Hi,
    2013 Ecoboost is surging, during idle it’s shaking the truck slightly, but when I’m driving down the road it feels like it’s surging, rpm gage is surging around 300rpm difference. When it’s on the higher PRM of the surge there’s this faint vibration that seems to be coming from the bottom somewhere, vibration at 70mph is around 2 Second intervals.
    I cleaned the MAP sensors and drilled the Intercooler, replaced the tires, shocks and struts but it’s still doing the same thing. Steering is nice and straight.. kind of wonder if it could be the driveline or torque converter.
    Anybody had something similar? What was the problem? Thanks,
    511
    127 times
    No brake pads dragging or anything like that? Process of elimination is going to be king here. Sounds like you have a good start on eliminating some of the usual suspects.
    Apr 2019
    13
    71098
    Don’t think it’s the brakes, but i guess it’s possible.
    But why would it only vibrate when it’s on the upper side of the RPM?
    3,891
    Quote Originally Posted by Vrooom View Post
    Hi,
    The suspension, tires or brakes are not going to be making it idle different.
    Have you replaced the spark plugs?
    Rookie 14 King's Avatar
    9
    66044
    Maybe try cleaning the MAF sensors? I have a rough idle. New plugs did not help. MAF are next on my to do list.
    511
    127 times
    I don't see that you've replaced spark plugs, as Noodles had said. You have a weep hole and already cleaned MAP sensors (There are 3). If you havent swapped plugs in the last 30K or so, I would try that. Also inspect your old plugs for any kind of cracks, as this is definitely an issue that's been seen. Might also pull battery cables, turn on the headlights to drain the power out for 5-10 mins, so your computer resets.
    It doesn't seem like drive line or anything like that, and I would be solely targeting that idle and see if that clears up your other issues you're having at speed.
    7,556
    3289 times
    Quote Originally Posted by 14 King View Post
    FYI, your 2014 doesn't have a MAF sensor. Only the 2011-2012 trucks had one. The 2013-2014 had 3 MAP sensors
    Rookie CombatDork's Avatar
    61554
    Definately check your spark plugs. Don't trust the pregapping.
    Ford has changed the recommended gapping for the EcoBoost several times.
    Gapping as small as .026 has been recommended however for your truck I would stick with .028. Most of the pregapped spark plugs will be gapped to .032 and you should close up the gap.
    Also, I would recommend finding full iridium spark plugs instead of just iridium tipped plugs because the EB GDI tends to burn up normal spark plugs.
    Apr 2019
    13
    71098
    Ok, got the spark plugs replaced, truck is still surging, it’s better at idle but on cruise it’s surging about the width of the dial indicator. I’m assuming it’s either the boost or the torque converter. Wondering what it could be.
    Replaced the plugs and boots today.
    Super Moderator Purefection's Avatar
    Manitoooba
    766
    65694
    328 times
    That sounds like torque converter
    Sent from my CLT-L04 using Tapatalk
  1. 2012 f150 surging
    By f150ecoboost in forum F150 Ecoboost Problems
    Last Post: 01-20-2019, 06:00 AM
  2. 2012 F150 Ecoboost Turbo surging
    By Chacemullin in forum F150 Ecoboost Problems
    Last Post: 01-08-2019, 09:00 AM
  3. 2013 3.5 surging and MPG issues
    By mreed1080 in forum F150 Ecoboost Problems
    Last Post: 09-20-2018, 04:42 PM
  4. 2011 F150, occasional boost 'flutter' / surging.
    By pfbz in forum F150 Ecoboost Performance
    Last Post: 12-02-2017, 06:10 AM
  5. 2012 F150 ecoboost surging during acceleration
    By JST4FN in forum F150 Ecoboost Problems
    Last Post: 08-31-2016, 11:53 PM
