2011-14 Real World STOCK Truck Mileage Expectations
This is a discussion on 2011-14 Real World STOCK Truck Mileage Expectations within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; If you drive this: Don't expect the mileage of this: I have been compiling some basic notes for over a year now. Anytime somebody has ...
Results 1 to 10 of 18
Like Tree15Likes
Thread: 2011-14 Real World STOCK Truck Mileage Expectations
    4,058
    3139 times
    If you drive this:
    I have been compiling some basic notes for over a year now. Anytime somebody has mentioned what their mileage is, I pay attention to the truck specifics and have written it down. Here is a loose representation of my findings. It is not exact and there are plenty of variables that could change the findings a little. I also did not offer expanded results for all the differing gear ratios or tow packages. But this listing is a decent indication of what a real-world driver could expect out of their new-to-them 2011-2014 Ecoboost F150 based on cab, bed, and drive configuration.
    Once again, these are not exact, and ANY modifications (programmer w/ tunes, lift, level, wheels, M/T or A/T tires, heavy aftermarket bumpers, etc.) to your stock truck will most likely lessen your mileage even more from what is listed here. This is only intended as a generic guide for your information.
    2011-2014 XL, XLT:
    SCab 2WD with 6.5' bed: 17/20
    SCrew 2WD with 5.5' bed: 17/20
    SCrew 2WD with 6.5' bed: 16/20
    SCab 4WD with 6.5' bed 16/19
    SCrew 4WD with 5.5' bed 16/19
    SCrew 4WD with 6.5' bed 15/18
    2011-2014 Sport, FX4, Lariat:
    SCab 2WD with 6.5' bed: 16/19
    SCrew 2WD with 5.5' bed: 16/19
    SCrew 2WD with 6.5' bed: 15/19
    SCab 4WD with 6.5' bed 15/18
    SCrew 4WD with 5.5' bed 15/18
    SCrew 4WD with 6.5' bed 14/17
    2011-2014 Platinum, King Ranch, Limited
    SCrew 2WD with 5.5' bed: 15/18
    SCrew 2WD with 6.5' bed: 15/18
    Blown F-150, Mr B, EcoXLT and 3 others like this.
    Eco-Beast EcoXLT's Avatar
    1,797
    6645
    883 times
    Mine is exactly in the range you posted. You have done well grasshopper.
    Elmore328 and winchested like this.
    6,547
    2616 times
    Perfect any further MPG whine threads should be locked immediately.
    Elmore328 likes this.
    Ecoboost Pro AllWhiteEco's Avatar
    Dyersburg, TN
    914
    5973
    383 times
    Great job on the research! I believe this is how the EPA should be rating MPG on the window stickers instead of just using the best case scenario (lightest configuration/lowest trim) and slapping that MPG claim on a fully loaded truck that is a few hundred pounds heavier. Maybe then the average person would not be outraged at their real world MPG.
    Elmore328 and Madd_cabbie like this.
    2014 Platinum
    3.31 E-Locker
    2.5" Rough Country Level
    22" Lariat Limited Wheels
    285/55R22 Nitto Trail Grappler M/T
    Boost Bars Lower Grille
    VTA mod
    AEM Drop-In Filter
    RX Monster w/ CSS
    Livewire TS w/ Custom tunes
    3" Catless Mak Y-Pipe
    Full 3" Catback Exhaust with Magnaflow #12579
    10" RF P2 w/ ported box
    Full LED Conversion w/ Switchbacks
    Rigid SAE Fog Lights
    4,058
    3139 times
    Thank you folks. I am working with some other members to compile a similar list for the 2015+ models.
    6,547
    2616 times
    Nobody seems to mention how fat the drivers and passengers are either.
    That makes a difference!
    Me, my wife and 2 kids don't total over 450 lbs.
    I'm sure theres some out there totalling over half that figure just as a driver.
    Ecoboost Pro MMCdude's Avatar
    west central Illinois
    553
    8345
    327 times
    What? Nobody else has an 8' bed? I'm right in line with the 6.5' bed SCab.
    _______________________________
    2014 F150 XLT Supercab, 3.5L EB, 3.73 axle, Max Tow Package, HD Payload Package (8200 GVWR), Kicker audio upgrade, wheel well liners, and trying to figure out how to squeeze in a CB and scanner...
    3,660
    3042 times
    Elmore, if my truck is a legit example, the 15+ would only be moved up 1-2 mpg.
    In other words, you have my configuration at 15-18 mpg. (KR Screw 4WD 5.5 bed)
    With the OEM tire size I'm a 16-19mpg
    Maybe a 16-20 range if you include the mizer-drivers.
    By the way, your a giver. Thanks man.
    Rookie ForceFed4g63's Avatar
    Oct 2018
    8
    68268
    This is spot on for me.
    4,058
    3139 times
    Quote Originally Posted by MMCdude View Post
    You're truck is equivalent to the mythical "unicorn"! I've heard people talk about EcoBoosts with an 8' bed. Seen pictures too.....
    But I've never personally seen one out in the wild or had the chance to touch it to see if they truly exist. LOL
    MMCdude likes this.
  1. Real world F150 Ecoboost Fuel Mileage
    Last Post: 05-17-2019, 10:52 PM
  2. Real world Mileage '14 SCREW FX4
    By Excalibur in forum F150 Ecoboost Performance
    Last Post: 06-13-2018, 02:01 PM
  3. Real World RV Towing Experience, Advice?
    By pagefamily96 in forum F150 Ecoboost Towing
    Last Post: 09-10-2014, 08:26 PM
  4. Tremor real world reviews
    By Yarbrouc in forum F150 Tremor
    Last Post: 12-11-2013, 06:01 PM
  5. Solo Dual catbacks for Eco boost real world reviews?
    By limited in forum F150 Ecoboost Performance
    Last Post: 10-12-2013, 04:16 PM
