Brake Vacuum Lost
Brake Vacuum Lost
This is a discussion on Brake Vacuum Lost within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; Problem: -Loss of vacuum in brake system after sitting for extended period of time (2+ hours). Brake pedal is stiff after it sits for this ...
Results 1 to 2 of 2
  • 2 Post By winchested
Thread: Brake Vacuum Lost
    Rookie BOW118MAN's Avatar
    May 2019
    Canada
    71402
    Brake Vacuum Lost
    Problem:
    -Loss of vacuum in brake system after sitting for extended period of time (2+ hours). Brake pedal is stiff after it sits for this amount of time. Revving engine up upon startup is required to build vacuum.
    Background:
    - 2012 F150 3.5L EcoBoost 145,000 KM
    - Vacuum pump has been replaced 2 times. 1st time was for the pump, second time was to fix issue I have but it didn't fix it
    - Pump seems to be running fine and no noise anymore since 1st replacement
    - Ford dealership wont investigate issue further unless I pay them.
    - There is a thread describing my exact problem but it has been dead since 2014 and no fix was mentioned. (https://www.f150ecoboost.net/forum/3...um-issues.html)
    Questions:
    - Is there a common check valve I should be replacing or looking into?
    - Any ideas on a fix?
    Thanks in advance!
    6,547
    2616 times
    There is the Vac line that goes to the main check valve on the booster and there is a small check valve in the Vacuum pump line.
    Its pretty easy to make sure the Vac pump is working by pulling the line and sticking a vacuum gauge in it and then pressing the brakes a few times until the pump comes on. If it isn't capable of at least 16 in/hg its bad. (you can buy a vac gauge at Princess auto for $15 and every at home mechanic should have one.)
    Beaker80 and Mikedick77 like this.
  1. 2013+ Brake Vacuum Pump Change
    By mooneywa in forum F150 Ecoboost Problems
    Last Post: 11-30-2016, 11:45 AM
  2. Continuing brake problems large brake pulsation
    By Spiro150 in forum F150 Ecoboost Problems
    Last Post: 07-04-2016, 08:33 AM
  3. Brake/Electronic Vacuum Pump issues?
    By FlyingMonkey in forum F150 Ecoboost Brakes
    Last Post: 04-30-2016, 12:28 PM
  4. Brake Vacuum Pump
    By DDColorado in forum F150 Ecoboost Brakes
    Last Post: 10-29-2015, 07:26 PM
  5. Lost permission
    By 2Canches in forum Off-Topic
    Last Post: 10-28-2015, 08:28 PM
