Bad Turbo, what do you think? - Page 3
This is a discussion on Bad Turbo, what do you think? within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; Originally Posted by Blown F-150 My $0.02 It does sound like a turbo is on it's way out. If it's a bearing, it's pretty easy ...
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 67
Like Tree26Likes
Thread: Bad Turbo, what do you think?
    1,157
    419 times
    My $0.02
    It does sound like a turbo is on it's way out. If it's a bearing, it's pretty easy to pop off the charge pipe and spin the turbine by hand. You'll know pretty quick if something is up.
    It could also be a manifold as suggested above. Check for broken studs, usually it's the lone rear one that let's go.
    As for GT's. I ran mine on a full bolt-on truck with the stock pump. I could really only run 91, so the power levels were not crazy. You can 100% run GT's on a stock HPFP, the tuner will need to taper in your boost accordingly.
    This is at roughly 4500ft. WGDC maxed out around 80% by the looks of it. I holds 18psi no problem. Same pull, same hill with @Grim Reaper and his truck would net about 14-15psi.
    Was @Boostking tuning you?
    I may be looking into this in the future. Im at 5500" so I know the struggle as well.
    3,056
    1084 times
    My $0.02
    I believe 80% is where the PCM considers the WG closed. I don't know if that means it was actually closed since the exhaust pressure can push it open, but it looks like the tune was trying fairly hard to make boost.
    When mine does 100% at 4500 RPM it makes me a little concerned to say the least.
    1,870
    1043 times
    I honestly donít know, but Iíve seen 100% WGDC with my current set up as we tried to find the limit of the 2019 ďHOĒ turbos. Iím testing @4000ft here.
    Just as a comparison, WOT in 3rd with my GTís @4500ish feet, WGDC was hovering around 80%. But thatís a perf tune, so not to sure how good info it is. This is also with Ported Manifolds.
    1,870
    1043 times
    Yes Sir, Brett dialled them right in for me.
    3,056
    1084 times
    I honestly don’t know, but I’ve seen 100% WGDC with my current set up as we tried to find the limit of the 2019 “HO” turbos. I’m testing @4000ft here.
    Just as a comparison, WOT in 3rd with my GT’s @4500ish feet, WGDC was hovering around 80%. But that’s a perf tune, so not to sure how good info it is. This is also with Ported Manifolds.
    If it was my truck and I saw 80% at higher RPM I would be fine with it. Thats probably the safe limit and Brett obviously knows whats up.
    What kind of airflow #'s were you seeing on the HO's?
    1,870
    1043 times
    We are around 51-52#'s/Min @ 20-21psi and around 11-12* of timing. Everything seems to be really happy around this level, so I think it's what we'll stick with.
    Again, take this comparison with a grain of salt, because I have a completely different motor now. Last tune we did for the GT's (truck ONLY had GT's and the FR CAC installed on the Stock motor), we were @ 43#'s/Min @18psi and 7* of timing. That ended up being 387/542 on the Dyno. Dyno was at 3500ft (although the Dyno should compensate for the altitude).
    At sea level with the GT's, the truck was 50#/min @18psi and 8-9* of timing.
    Ecoboost Veteran jibtechwarrior's Avatar
    edmonton, alberta
    281
    61321
    68 times
    FWIW, sounds exactly like my 2012 did when it warped the P/S manifold.
    3,056
    1084 times
    Quote Originally Posted by jibtechwarrior View Post
    Yeah, I've pretty much settled on this. Gunna pick up a set of CRP's. Waiting to see if there will be a Memorial day sales and drive my Jeep in the meantime. Diesel is cheaper than 88 octane here anyways.
    3,056
    1084 times
    Order myself a set of CRP Manifolds and all the gaskets, bolts and studs i would need to do a swap. Hopefully its not too much of a pain.
    Big turbos are likely gunna happen down the road.
    Blown F-150 and Sirikenewtron like this.
    3,056
    1084 times
    Whoever guessed broken rear stud, you win the prize:
    Also, **** the jiffy tite connectors.
    Envious and Blown F-150 like this.
  1. I got my Lower Bumper grill at VanderFab.com what do you think
    By BigStang in forum F150 Ecoboost Accessories
    Last Post: 03-14-2016, 12:20 PM
  2. What do you think of this cheap Chinese F150?
    By TorqueNews in forum F150 Ecoboost News
    Last Post: 05-20-2014, 12:42 AM
  3. 2014 Toyota Tunda is announced, what do you think?
    Last Post: 07-22-2013, 10:52 PM
  4. What do you think of the Worx 804 Tank Wheel?
    By STdan in forum F150 Ecoboost Wheels and Tires
    Last Post: 04-17-2013, 09:58 AM
