Bad Turbo, what do you think? - Page 6
This is a discussion on Bad Turbo, what do you think? within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; I’ve done a few turbo swaps now and have gotten lazy when it comes to the downpipes. I just undo the nuts on the adapters ...
Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 67
Like Tree26Likes
Thread: Bad Turbo, what do you think?
  1. #51
    1,928
    1104 times
    I’ve done a few turbo swaps now and have gotten lazy when it comes to the downpipes. I just undo the nuts on the adapters and then crawl under the truck. I place my foot on the frontside of the muffler and give’er a good boot. The whole assembly slides back and gives you some clearance to mess with the turbos.
    snakebitten and WooBoost like this.
  2. #52
    855
    279 times
    Had I known you could get at the front O2 sensors through the wheel wells with the proper wrench, I probably would have left them in place. I definitely recommend the "boot method". Nothing like laying on your back trying to wrestle 75+ pounds overhead while aligning two ends of a y-pipe going in different directions.
  3. #53
    3,239
    1156 times
    If the nut is seized on there, it will simply unscrew from the head. Mine were not tight at all. The bigger pain is removing the downpipe flange nuts off the turbo. If the truck is still warm, this may be an issue dealing with the exhaust side. Hit everything with penetrating oil a coupld times, a few days beforehand.
    This. The nuts came off no problem after sitting for 15 minutes in PB blaster. I think 4 studs total came out with the nuts. The remaining studs also removed with no trouble. This is with 70k miles and salty winters.
    Even the broken stud came out no problem with a double nut:
    Blown F-150 likes this.
  5. #54
    3,239
    1156 times
    Yeah **** the down pipes. I should have done this since I pulled the turbos out the top anyways. I swear to god the bolts under the truck were all tightened by the incredible hulk and I had to use my extension on a bunch of them. Spent way to much time just getting the downpipes off.
  6. #55
    4,224
    1218 times
    I watched a video on turbo install on youtube, he didnt remove the downpipe? You unbolt it obviously at the turbo but you don't have to actually remove it from the hangers underneath and stuff do you?
  7. #56
    3,239
    1156 times
    If you follow the CRP instructions they tell you too. You gotta drop the trans cross memeber and remove the trans mount from the transmission to get the crossover pipe free. If you didnt have to do this and didnt have to unplug the O2 sensors it would save you a **** load of time
  8. #57
    855
    279 times
    I have pulled the driver's side turbo without taking the downpipe off the hangers. The challenge is there is a 4th mounting bolt for the turbo "behind" the turbo. It's not just hanging there on the exhaust manifold by the 3 bolts you can easily see. This 4th bolt is attached to a bracket which is furthermore attached to the head. From what I recall, the service manual has you snug the turbo to the bracket, then the bracket to the head. In that order. I assume this makes sure there is no binding or stress at the turbo mounting point. Problem is, it's difficult to torque that bracket down to the head with the exhaust pipe in place. It seemed like some of the steps in the manual were backwards or out of place, because I could not get at some of the bracket bolts by torquing the turbo to it first.
    Try it first without taking it off the hangers. It will save a few hours easily. You could always bite the bullet and lower it if it's in your way.
  9. #58
    3,239
    1156 times
    I saw reference to these 4th bolts in the CRP installation guide, but I think they may have gone away in 2013. Mine certainly did not have them so I suspect any trucks with the 13'+ turbos don't.
    As far as the turbos go, I was able to pull both out the top anyways. The passenger side is tight and I actually pulled it out after I removed the stock manifold, and then put it back in resting down on the side of the transmission before putting the CRP mani's in. So the turbo was just sitting down below the manifold while I was torquing the nuts on the mani.
  10. #59
    4,224
    1218 times
    Theres no way i am pulling that and the cross memeber(really?) unless I absolutely have to....we will see when **** starts coming apart.
  11. #60
    855
    279 times
    Lucky dog. Figures the year truck I bought has the most difficult to assemble setup!
    Mine was slightly bent from the prior owner hitting something, so the bolt holes were misaligned. Took a 30" breaker bar, 10 lb sledge, a crowbar and lots of sweat to get the bolts out. I thought for sure I was going to snap a bolt. Not fun at all.
  1. I got my Lower Bumper grill at VanderFab.com what do you think
    By BigStang in forum F150 Ecoboost Accessories
    Last Post: 03-14-2016, 12:20 PM
  2. What do you think of this cheap Chinese F150?
    By TorqueNews in forum F150 Ecoboost News
    Last Post: 05-20-2014, 12:42 AM
  3. 2014 Toyota Tunda is announced, what do you think?
    Last Post: 07-22-2013, 10:52 PM
  4. What do you think of the Worx 804 Tank Wheel?
    By STdan in forum F150 Ecoboost Wheels and Tires
    Last Post: 04-17-2013, 09:58 AM
