2012 F150 Lariat EcoBoost Rear Defrost/Defog Issue
This is a discussion on 2012 F150 Lariat EcoBoost Rear Defrost/Defog Issue within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; Hi all, I just purchased a 2012 F150 Lariat (EcoBoost; 2x4) from a private seller. I often find myself using the rear defrost on my ...
Results 1 to 7 of 7
  • 1 Post By DNA Dan
Thread: 2012 F150 Lariat EcoBoost Rear Defrost/Defog Issue
    Rookie Shinespike's Avatar
    May 2019
    4
    71532
    Hi all,
    I just purchased a 2012 F150 Lariat (EcoBoost; 2x4) from a private seller. I often find myself using the rear defrost on my car for defogging purposes in the morning. I went to turn it on in the truck and the light isn't indicating that it is working. Tried it again this morning and it turned on for a brief moment, and then disconnected. I did some research and found older threads (from 2011 and 2015) talking about similar issues. I was wondering if there was ever any general consensus on a fix? If it matters, the truck has 67,225 miles at the time of this writing. Thanks!
    1,150
    416 times
    Mine is broke but I do not mind it being broke. A lot of reports of back windows shattering when using it.
    823
    258 times
    HOLD UP!! If you bought it from a private seller they may have disconnected something on purpose. People were doing this because the window can shatter from using the rear defroster. Not sure what the solution is to fix, but many just disconnected the window.
    May 2019
    4
    71532
    Wow, I didn't realize windows were actually shattering. o.O I have a basic oil change and multi point inspection scheduled for today, so I suppose I could see if they notice anything. I'm trying to avoid a dealer's insane charge for a diag scan. I did read about the windows disconnecting if they're even slightly open, but I haven't had a chance to double check that just yet.
    If anyone else knows of any other solutions out there, please let me know. Thanks for the replies!
    Ecoboost Jr Member 0949er's Avatar
    NC
    22
    5304
    I am also interested in this as I have the same issue (2014 eco 80k miles) rear defrost will not enable/illuminate on the dash, will not turn on, no blown fuses / etc.
    Olathe Ks
    757
    14790
    214 times
    ~Jim~
    2012 Lariat Screw; 3.5L; 4x4; 3.55 E-Locker; Lux/Tow Package;
    Exhaust; 3" Resonator Delete;Turbosmart BOVs; Bilstein 5100s; Leveled; 20% Window Tint; Full Interior LEDs; PIAA Heads/Fogs; Forscan; BFG 275/70/18 AT KO2s
    Ecoboost Sr Member mamaxwell's Avatar
    Jun 2013
    Coeur d Alene ID
    78
    1368
    Mine did the same thing it was under warranty so took it to Ford, their fix was to replace the rear window. They told me the contact in the window goes bad and the defrost will not turn on.
    Max
    Code Enforcement Officer. USCG Ret.
    2012 Gem Green XLT.
  1. Rear Defrost
    By NFLD in forum F150 Ecoboost Electronics
    Last Post: 01-12-2019, 06:08 PM
  2. Rear window defrost
    By Topflight in forum F150 Ecoboost Problems
    Last Post: 01-04-2019, 10:35 PM
  3. Rear Defrost Button
    By Petek in forum F150 Ecoboost Problems
    Last Post: 11-20-2018, 11:17 PM
  4. 2013 KR Rear Defrost
    By ross1147 in forum F150 Ecoboost Problems
    Last Post: 02-03-2018, 08:16 PM
  5. Airbag Light, traction control, Hazard lights, & rear defrost all quit
    By ScottyB351w in forum F150 Ecoboost Problems
    Last Post: 03-15-2017, 04:41 PM
