2012 F150 Ecoboost, p0017 code
This is a discussion on 2012 F150 Ecoboost, p0017 code within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; So I have been researching all the F150 sites for the last several weeks. Have a 2012 F150 XLT ecoboost. 80K miles, throwing the P0017 ...
Results 1 to 3 of 3
  • 1 Post By noodles
Thread: 2012 F150 Ecoboost, p0017 code
    Rookie John6385's Avatar
    May 2019
    71574
    Post 2012 F150 Ecoboost, p0017 code
    So I have been researching all the F150 sites for the last several weeks. Have a 2012 F150 XLT ecoboost. 80K miles, throwing the P0017 code occasionally. Literally the CEL will go on and off throughout the day. As well as have decreased power sometimes, but not all the time. Had a certified Ford mechanic friend of a friend do a basic Ford computer hookup to just rule out the known timing chain issue. Ford mechanic said the timing chain was fine, as where the cam and turbos. Have done the suggestion of changing the oil and spark plugs. None of this has rectified the CEL yet. Thoughts?
    511
    127 times
    Quote Originally Posted by John6385 View Post
    I'm pretty sure that's crankshaft sensor for the code. Changing plugs and oil will do nothing for that. I haven't had the code, but pretty sure you're changing the crank shaft sensor. I'd think a certified Ford mechanic could have told you what this was, and may have been able to fix this.
    Good luck with the repair. If this were me, it'd be something i'd want fixed with all haste.
    3,891
    P0017 is related to crank-camshaft being out of sync on bank 1 (pass side). It can be caused by a bad VCT, VCT solenoid, crank sensor, or timing chain being stretched enough to throw them out of sync.
    Do you have a rattle at start up after a long cold soak (overnight)?
  1. P0017 - Crank/Cam and Loss of Power
    By dell30rb in forum F150 Ecoboost Problems
    Last Post: 04-02-2019, 09:12 PM
  2. Random P0017 and/or P0019 after timing chain fix
    By 13dunndm in forum F150 Ecoboost Problems
    Last Post: 06-23-2018, 11:15 AM
  3. P0016 and p0017
    By Drewbley in forum F150 Ecoboost Problems
    Last Post: 06-21-2018, 08:44 PM
  4. DTC Codes P0016, P0017 & P0172 help
    By Bruce180vf in forum F150 Ecoboost Problems
    Last Post: 05-28-2018, 11:38 AM
  5. 2011 with P0017-P0019 (NOT P0016)
    By papacamper in forum F150 Ecoboost Problems
    Last Post: 01-09-2017, 07:18 AM
