Axle dumped exhaust - Page 2
Axle dumped exhaust
This is a discussion on Axle dumped exhaust within the 2nd Gen F150 Ecoboost forums, part of the 2nd Gen F150 Ecoboost Forum (2015+) category; What is the difference between the 12579 and the 12589? AK4wheeler...
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Like Tree10Likes
Thread: Axle dumped exhaust
    Ecoboost Veteran AK4wheeler's Avatar
    May 2016
    Charleston, SC
    419
    16003
    121 times
    AK4wheeler
    Ecoboost Regular NorthsideFord's Avatar
    Effingham, IL
    233
    53137
    101 times
    Quote Originally Posted by AllWhiteEco View Post
    I did the Magnaflow 12579 with O/R DPs. It has a great tone to it and what I would highly recommend to anyone looking for a muffler swap.
    @NorthsideFord The one you listed was for the offset inlet? Is that the one that you used or was it the the center in/out which is the 12579 I am running.
    Yes, I used the 12589, and retained the 3" over axle factory piece. It is a 3" in/out and center/offset, fits perfectly and entire 3" exhaust system cost me a total of 200$.
    I have 3" Livernois downpipes as well and I like the sound.
Size:  1.21 MBName:  IMG_0183.JPG
    Main Vehicle DD:
    2016 3.5 Ecoboost 2WD Sport LE 3.55 Rear w/ E-Locker Shortbox
    Mods:
    1.75" Rear Drop / K&N Procharder CAI / Livernois 3" Downpipes / 3" Magnaflow Exhaust / Livernois Intercooler / Livernois 160 Tstat / NGK Plugs / SPD Adapters
    Effingham, IL
    233
    53137
    101 times
    Quote Originally Posted by AK4wheeler View Post
    AK4wheeler
    The 12579 is 3" in/out as well but it is, center/center. Meaning the inlet and outlet are both in center of the muffler. I wanted to retain and use the 3" over the axle mandrel bent piece, so I just cut it off right at the edge of factory muffler, and used a 12589 because the factory is center/offset.
    Main Vehicle DD:
    Mods:
    Ecoboost Pro AllWhiteEco's Avatar
    Dyersburg, TN
    914
    5973
    384 times
    Quote Originally Posted by NorthsideFord View Post
    Yeah I went the same route just the 12579 which is 3” center in/out. I had the exhaust shop weld in 3” straight with flange from DP to muffler then retained the 3” over axle section. I’m at around $550 for my complete turbo back exhaust (Downpipe included). I’ve been running MAK catless downpipes for 70,000 miles now with stock catback, res delete/stock muffler, and now this Magnaflow. The Magnaflow is by far my favorite sound after spending time with the various setups. My biggest complaint with stock catback and DPs was the buzzing and raspiness you get at WOT especially in the higher rpms. The Magnaflow eliminated this entirely without the need to add an aftermarket resonator which is a big plus. This is definitely your best bang for you buck if you can’t justify spending $700 on a catback exhaust that is purely for sound.
    NorthsideFord likes this.
    2014 Platinum
    3.31 E-Locker
    2.5" Rough Country Level
    22" Lariat Limited Wheels
    285/55R22 Nitto Trail Grappler M/T
    Boost Bars Lower Grille
    VTA mod
    AEM Drop-In Filter
    RX Monster w/ CSS
    Livewire TS w/ Custom tunes
    3" Catless Mak Y-Pipe
    Full 3" Catback Exhaust with Magnaflow #12579
    10" RF P2 w/ ported box
    Full LED Conversion w/ Switchbacks
    Rigid SAE Fog Lights
    Effingham, IL
    233
    53137
    101 times
    Those 700$ systems don't sound much if any different, just better quality 3" pipe in the deleted section and over the axle. But to me I could replace that 3" pipe 5x for the cost they want for the full systems. I have 3" downpipes with race cats, and the exhaust explained above, I am from the turbos back into the whole system for around $750, only difference is the AR downpipes with cats are more expensive than the O/R Mak. Both excellent products though.
    AllWhiteEco likes this.
    Main Vehicle DD:
    Mods:
    Dyersburg, TN
    914
    5973
    384 times
    Axle dumped exhaust
    This is what my stock exhaust looked like. Remember that my truck is an 11-14 body style so the exhaust might be slightly different. To me it looked like a center in/out would allow the pipes to remain in the factory location compared to offsetting it on one side. That’s what ultimately led me to purchasing the 12579. Any pics of your stock muffler?
    2014 Platinum
    3.31 E-Locker
    VTA mod
    AEM Drop-In Filter
    RX Monster w/ CSS
    Effingham, IL
    233
    53137
    101 times
    @AllWhiteEco I don't have right now, its in storage down at the farm.
    Its slightly different though.
    Main Vehicle DD:
    Mods:
    Dyersburg, TN
    914
    5973
    384 times
    Axle dumped exhaust
    Good to know, a 12579 is direct fit for 11-14 and 12589 direct fit for the 15+ trucks. I believe that @bespurcell is also running the 12579 Magnaflow on his 11-14 truck with stock downpipes.
    2014 Platinum
    3.31 E-Locker
    VTA mod
    AEM Drop-In Filter
    RX Monster w/ CSS
    Gold Supporting Member bespurcell's Avatar
    Apr 2017
    OK
    1,107
    33505
    320 times
    Yes I am running the 12579 and love the way it sounds. Deep and mellow at all throttle openings.
    2012 supercrew Lariat 4wd 3:55 ELD SCT X4 Gearhead tune, 3" Magnaflow, deleted resonator and replaced with 3" pipe, Mishimoto CAC and cold side pipes
    Dyersburg, TN
    914
    5973
    384 times
    AK4wheeler
    The mufflers are the same with the in/out orientation being the only difference. It should give the same sound, just depends which fits your application.
    2014 Platinum
    3.31 E-Locker
    VTA mod
    AEM Drop-In Filter
    RX Monster w/ CSS
  1. Stock axle ratio
    By freakoboost 2012 in forum F150 Ecoboost Purchasing
    Last Post: 05-11-2015, 03:47 PM
  2. MAK carless downpipes dumped after resonator
    By Fly boy in forum F150 Ecoboost Performance
    Last Post: 03-08-2015, 06:57 PM
  3. What's Your Rear Axle
    By Don SC in forum F150 Ecoboost Towing
    Last Post: 01-22-2015, 05:53 AM
  4. What is the best rear axle?
    By tredawg4evr in forum F150 Ecoboost Chat
    Last Post: 06-09-2013, 12:29 AM
  5. axle code
    By cnrwbaker in forum F150 Ecoboost Towing
    Last Post: 05-03-2013, 06:25 PM
dumped
