Axle dumped exhaust - Page 3
Axle dumped exhaust
This is a discussion on Axle dumped exhaust within the 2nd Gen F150 Ecoboost forums, part of the 2nd Gen F150 Ecoboost Forum (2015+) category; Originally Posted by AllWhiteEco Good to know, a 12579 is direct fit for 11-14 and 12589 direct fit for the 15+ trucks. I believe that ...
Results 21 to 30 of 33
Like Tree10Likes
Thread: Axle dumped exhaust
    Ecoboost Master TOWMA8R's Avatar
    Sep 2017
    Two States
    1,406
    44498
    493 times
    Quote Originally Posted by AllWhiteEco View Post
    Good to know, a 12579 is direct fit for 11-14 and 12589 direct fit for the 15+ trucks. I believe that @bespurcell is also running the 12579 Magnaflow on his 11-14 truck with stock downpipes.
    Thanks all for the clarifications. So the 12589 is what I need to run. Any sound clips from the ones running it?
    2019 F150 CC FX4 XLT - Max Tow & Much More
    RIP-2015 CC FX4 l 3.55's l Raptor Style Grille l Level 2" l 305/60/18 on Vision Manics l Bilstein 4600's l Powerstop Z36's l AEM CAI l MSD Coils l Exhaust Tweaks l Tow Mirrors l Upgraded Trans Cooler (GH 13.31 1/4)
    Ecoboost Jr Member van462's Avatar
    Aug 2017
    Bremerton WA
    36
    42178
    Have you been anywhere where its dusty to see it turns into a dust cloud with it pointed down?. I am offroad a bit and don't like that the side exhaust gets coated in mud or pile of fir needles.
    Ecoboost Regular tuck3r's Avatar
    Dec 2014
    Okanagan
    231
    7242
    80 times
    Not sure how comparable it is but, I have the Magnaflow 19054 catback. Dual outlet passenger side infront of the rear tire. I put a resonator in. Way to loud/droney out of the box.
    Appearance wise, you can't beat it IMO.
    2015 FX4 SCrew 2.7L with some stuff and things that make me smile
    Ecoboost Pro AllWhiteEco's Avatar
    Dyersburg, TN
    914
    5973
    384 times
    Quote Originally Posted by tuck3r View Post
    Looks like your muffler is a 5”x8” oval that is 18” long. The 12579/89 is a 5x11” oval case this is 22” long. The larger casing allows for more sound deadening. However, an oval muffler is still going to cut down more sound than a round one of the same length. I’m sure the location of your exhaust exit also plays a role in the drone.
    2014 Platinum
    3.31 E-Locker
    2.5" Rough Country Level
    22" Lariat Limited Wheels
    285/55R22 Nitto Trail Grappler M/T
    Boost Bars Lower Grille
    VTA mod
    AEM Drop-In Filter
    RX Monster w/ CSS
    Livewire TS w/ Custom tunes
    3" Catless Mak Y-Pipe
    Full 3" Catback Exhaust with Magnaflow #12579
    10" RF P2 w/ ported box
    Full LED Conversion w/ Switchbacks
    Rigid SAE Fog Lights
    Sep 2017
    Two States
    1,406
    44498
    493 times
    Quote Originally Posted by van462 View Post
    The diesel exhaust has more volume and creates more out pressure and my diesels were stock height. i did extensive off road and there will be no dust issue, at all.
    Ecoboost Regular NorthsideFord's Avatar
    Effingham, IL
    233
    53137
    101 times
    Quote Originally Posted by TOWMA8R View Post
    I will get you a sound clip of a cold start and cruising down the highway with the 12589 tomorrow morning/day.
    TOWMA8R and AllWhiteEco like this.
    Main Vehicle DD:
    2016 3.5 Ecoboost 2WD Sport LE 3.55 Rear w/ E-Locker Shortbox
    Mods:
    1.75" Rear Drop / K&N Procharder CAI / Livernois 3" Downpipes / 3" Magnaflow Exhaust / Livernois Intercooler / Livernois 160 Tstat / NGK Plugs / SPD Adapters
    Effingham, IL
    233
    53137
    101 times
    @AllWhiteEco as well, will get better clip in the morning when I leave hotel. Also will get some interstate cruising.
    AllWhiteEco likes this.
    Main Vehicle DD:
    Mods:
    Dyersburg, TN
    914
    5973
    384 times
    Quote Originally Posted by NorthsideFord View Post
    Sounds just like mine every morning, nothing like sweet turbo whistle in the AM! I’ve added a couple pictures of my exhaust to this post just for reference if anybody needs to describe what they want done to an exhaust shop. Also to show clearances of the Magnaflow 12579 5”x11” oval casing.
    2014 Platinum
    3.31 E-Locker
    VTA mod
    AEM Drop-In Filter
    RX Monster w/ CSS
    Sep 2017
    Two States
    1,406
    44498
    493 times
    I wanna hear!
    Dyersburg, TN
    914
    5973
    384 times
    I wanna hear!
    Do you plan on upgrading downpipes in the future? That will increase the sounds significantly and also deepen the tone some. I found this clip of 12579 with stock downpipes and res delete. I hope bespurcell doesn’t miss me posting it.
    2014 Platinum
    3.31 E-Locker
    VTA mod
    AEM Drop-In Filter
    RX Monster w/ CSS
  1. Stock axle ratio
    By freakoboost 2012 in forum F150 Ecoboost Purchasing
    Last Post: 05-11-2015, 03:47 PM
  2. MAK carless downpipes dumped after resonator
    By Fly boy in forum F150 Ecoboost Performance
    Last Post: 03-08-2015, 06:57 PM
  3. What's Your Rear Axle
    By Don SC in forum F150 Ecoboost Towing
    Last Post: 01-22-2015, 05:53 AM
  4. What is the best rear axle?
    By tredawg4evr in forum F150 Ecoboost Chat
    Last Post: 06-09-2013, 12:29 AM
  5. axle code
    By cnrwbaker in forum F150 Ecoboost Towing
    Last Post: 05-03-2013, 06:25 PM
dumped
