2018 stock filter vs K&N filter ?
This is a discussion on 2018 stock filter vs K&N filter ? within the 2nd Gen F150 Ecoboost forums, part of the 2nd Gen F150 Ecoboost Forum (2015+) category; I have a stock truck and is the factory filter bad ? Would a K&N filter be better help gas mileage than the stock one ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Like Tree14Likes
Thread: 2018 stock filter vs K&N filter ?
    Ecoboost Sr Member dwayne.surratt's Avatar
    Nov 2018
    67
    68454
    I have a stock truck and is the factory filter bad ? Would a K&N filter be better help gas mileage than the stock one ? I’m not going to do anything else to the truck
    Utah
    1,401
    27626
    776 times
    If you constantly drive the truck hard, changing to a K&N may yield positive results.
    ΜΟΛΩΝ ΛΑΒΕ
    Oc
    674
    4453
    251 times
    K&n does not filter as well as a paper filter. You will notice zero improvement in mileage and zero butt dyno improvement. The only improvement from a K&N will be accelerated wear on your motor due to it letting in the fine dust particles that the stock paper filter actually filters out.
    N4HHE, mmateri and Poppy58 like this.
    Nov 2018
    67
    68454
    I found this and I think I’ll replace it when it comes time
    Puyallup, WA
    946
    4854
    421 times
    If your goal is mpg's, not sure you'll be happy.. But, if you want 14 hp more at 7000 rpms, go for it!
    Good luck!
    Mitch
    mwemaxxowner likes this.
    491
    66176
    215 times
    However, that video only applies to the G37. The F150 filter is much larger, with a totally different airbox design. Is the G37 somewhat starved for air at WOT, whereas the F150 isn't, using the stock filter?
    Here's another video, done similarly, that claims 5hp and 3lb-ft, for a 90s F150:
    5hp/3lb-ft are well within the margin of error.
    And then you have the whole debate of filtration versus flow. You could remove the filter altogether and you'd get substantially better flow. But, I would be especially concerned about filtration with a turbocharged motor.
    GearHead_1 likes this.
    9,235
    3624 times
    With a turbocharger pulling air in forcefully, I don't even think you'd see a substantial increase in flow then.
    Baaaaaaaaaaa
    Nov 2018
    67
    68454
    I was going to wait till after the first oil change and dyno the truck just to see what hp it puts to the wheels. For less than 50.00 I can get a filter and see if it’s any power increase. You get 2 pulls on the dyno so I’ll know if I wasted another 50.00 or not
    491
    66176
    215 times
    Just remember, you can only test power... not filtration. Pull the filter entirely and the dyno will look even better! The engine just won't last very long.
    N4HHE likes this.
    Olathe Ks
    770
    14790
    222 times
    Check out the AEM dry drop-in filter. It filters great and has no oil to mess with sensors
    ~Jim~
    2012 Lariat Screw 3.5L; 4x4; 3.55 E-Locker; Lux/Tow Package;
    Exhaust; 3" Resonator Delete;Turbosmart BOVs; Bilstein 5100s; Leveled; 20% Window Tint; Full Interior LEDs; PIAA Heads/Fogs; Forscan; BFG 275/70/18 KO2s; Fuel Hostage 18x9
  1. Drop In vs. Stock Air Filter
    By MSparks909 in forum F150 Ecoboost Performance
    Last Post: 01-08-2015, 06:29 PM
  2. sctx4 , is there an option to change from stock to k&n drop in filter
    By pred03tld in forum F150 Ecoboost Performance
    Last Post: 10-29-2014, 09:08 PM
  3. Replies: 27
    Last Post: 10-07-2014, 08:37 PM
  4. k&n drop in filter or wait and get a s&b cai ?
    By pred03tld in forum F150 Ecoboost Maintenance
    Last Post: 09-23-2014, 11:03 AM
  5. f150 vs silverado vs RAM vs Tundra vs Titan - Fuel economy research
    By Chupa in forum F150 Ecoboost vs The Competition
    Last Post: 12-18-2013, 07:46 PM
