I did a search
I did a search
This is a discussion on I did a search within the 2nd Gen F150 Ecoboost forums, part of the 2nd Gen F150 Ecoboost Forum (2015+) category; Does that mean I can run e-85 ? Sent from my iPhone using Tapatalk...
Results 1 to 10 of 13
Like Tree3Likes
Thread: I did a search
    Ecoboost Sr Member dwayne.surratt's Avatar
    Nov 2018
    67
    68454
    I did a search
    Ecoboost Veteran D0ncH's Avatar
    Nova Scotia, Canada
    499
    24850
    144 times
    I believe that means for can run 0-15% ethanol which is E0-E15. E85 is 85% ethanol
    dwayne.surratt likes this.
    2017 2.7L Bronze Fire 4x4 3.55 145" | Gearhead Tune | UPR DVCC + CSS | Ford Performance Super 8.8" LSD | Hellwig front/rear sway-bar | 12Volt Solutions Remote Starter | Ford Tri-fold tonneau cover | Line X bed liner | Huskey front/rear mud guards & rear wheel well liners | AVS Aeroskin hood shield | Rear block removed
    Ecoboost Veteran miniceptor86's Avatar
    Mar 2015
    NE Iowa
    488
    8785
    193 times
    Quote Originally Posted by D0ncH View Post
    That's a no!
    Cheers,
    Jim
    2014 FX4 screw, Ruby Red, 402A, 3.55, 5.5, factory spray in bed liner, LT tires, BAKflip VP, custom engine, air and fuse box covers, Custom Cab, Ford mud flaps
    Nov 2018
    67
    68454
    Olathe Ks
    762
    14790
    215 times
    The 0 to E15 means you can run pump gas with ethanol percentage up to 15%. Most gas you buy has this in it.
    ~Jim~
    2012 Lariat Screw 3.5L; 4x4; 3.55 E-Locker; Lux/Tow Package;
    Exhaust; 3" Resonator Delete;Turbosmart BOVs; Bilstein 5100s; Leveled; 20% Window Tint; Full Interior LEDs; PIAA Heads/Fogs; Forscan; BFG 275/70/18 KO2s
    Nova Scotia, Canada
    499
    24850
    144 times
    Quote Originally Posted by miniceptor86 View Post
    That's a no!
    Care to explain?
    Ecoboost Pro AllWhiteEco's Avatar
    Dyersburg, TN
    918
    5973
    384 times
    Care to explain?
    I would assume his comment means that not all E85 is truly 85% ethanol and that the actual ethanol percentage in E85 can vary from station to station. That is why you see people with those ethanol testers when they are running blends like E30 or E50 tunes.
    2014 Platinum
    3.31 E-Locker
    2.5" Rough Country Level
    22" Lariat Limited Wheels
    285/55R22 Nitto Trail Grappler M/T
    Boost Bars Lower Grille
    VTA mod
    AEM Drop-In Filter
    RX Monster w/ CSS
    Livewire TS w/ Custom tunes
    3" Catless Mak Y-Pipe
    Full 3" Catback Exhaust with Magnaflow #12579
    10" RF P2 w/ ported box
    Full LED Conversion w/ Switchbacks
    Rigid SAE Fog Lights
    Nova Scotia, Canada
    499
    24850
    144 times
    Quote Originally Posted by AllWhiteEco View Post
    That's not how I read the original post with the picture of the gas cap. He was reading the E15 as 85% ethanol
    Nov 2018
    67
    68454
    I was asking if the EO-E15 was e85 because I have never see EO-E15 at the pumps. I didn’t know that there was a E15 fuel
    7,614
    3311 times
    You stated you did a search...here is another one that should explain it in a little more depth.
    LMGTFY
  1. how to use the search option!!!??
    By Tuffmag in forum F150 Ecoboost Chat
    Last Post: 09-15-2014, 12:06 PM
  2. Did you know your seats did this?
    By japeatr in forum F150 Ecoboost Photos/Videos
    Last Post: 08-09-2014, 01:39 PM
  3. Newb, in search of…….
    By myold32 in forum Introductions
    Last Post: 05-15-2014, 09:05 AM
  4. TPMS help please... the more I search the more confused i'm getting!
    By tmd07 in forum F150 Ecoboost Wheels and Tires
    Last Post: 03-14-2014, 07:33 AM
  5. In search of a tonneau cover
    By NewEcoBeast in forum F150 Ecoboost Accessories
    Last Post: 01-14-2014, 03:46 PM
