Gas mileage when towing a trailer - Page 2
This is a discussion on Gas mileage when towing a trailer within the 2nd Gen F150 Ecoboost forums, part of the 2nd Gen F150 Ecoboost Forum (2015+) category; Currently a 25 ft Rockwood UltraLite 6400 dry weight/ 7200 loaded behind my 2018 S/crew with 3.5 10 speed 3.55 gears and 1785 carry capacity. ...
Results 11 to 20 of 30
Like Tree7Likes
Thread: Gas mileage when towing a trailer
    Ecoboost Sr Member Tuctuckr2@comcast.netkr2's Avatar
    Nov 2017
    Puyallup, Washington
    56
    50746
    Currently a 25 ft Rockwood UltraLite 6400 dry weight/ 7200 loaded behind my 2018 S/crew with 3.5 10 speed 3.55 gears and 1785 carry capacity. Towing at speeds 65-70 mph I see 10.5-12 mpg. Without the trailer I frequently see 19-21 mpg (hand calculated).
    If your getting 11.8 your are well ahead of the curve.
    2018 F150 XLT S/Crew 4x4, FX4-off Road, 157 wb, 3.5L, 3.55 E-lockr, max trailer tow, tow mirrors, line-X bedliner, ARE Canopy, Falken Wildpeak AT3 LT275/70/18, husky flaps.
    Smile, Itís the second best thing you can do with your lips!
    Eco-Beast madmaxmutt's Avatar
    Colorado Springs
    3,477
    3707
    1608 times
    You cannot have Eco and Boost. Spin those two little fans and the gas mileage will drop. Even true on my PSD.
    J-Winship likes this.
    2017 Ford F350 Lariat FX4 SRW 4x4
    2017 Ford Explorer Sport 3.5 Ecoboost.
    Traded my boost: 2013 Ford F150 Ecoboost FX4 SuperCrew.
    Should've got a V8 - Check
    Should've got a Diesel - Check
    Should've got a 1 Ton - Check
    You'll run out of payload - Not Likely
    3,490
    1786 times
    I can tell you that I am THRILLED with my 14` Boost mpg's when towing my 38' 9k+ dry Keystone Outback...getting 8-10mpgs- it's a beautiful thing and while passing diesel pickups towing 25' TT's-lol... up 7% grades at 7500' above sea level.
    noodles likes this.
    Ecoboost Veteran surf_ox's Avatar
    Cypress, TX
    252
    11671
    63 times
    Quote Originally Posted by farupp View Post
    Thanks for the quick responses, and I'm glad to hear the the mpg is of 12+/- is as expected. I didn't know what to expect.
    Frank
    And to set your mind at ease the diesels do the same thing only variable is diesel costs more per gallon.
    7,568
    3293 times
    Quote Originally Posted by surf_ox View Post
    And oil changes are more expensive, and they are harder to park, and the list goes on. lol
    Cypress, TX
    252
    11671
    63 times
    Yep cheapest I found when I had my 6.4 was 89 bucks
    milesej05 likes this.
    Ecoboost Sr Member Bird1's Avatar
    Jan 2018
    Southern Illinois
    56
    54266
    17 times
    To the original poster I have a 14 model 3.5 Ecoboost with the 6 speed auto, 3.31 rear end, 4wd Supercab and when I hook up my 3 horse bumper pull trailer with tack and three horses I am nearing 7000 lbs or sightly more and I get roughly the same fuel mileage. Unloaded I get 18-19 on the interstates and I can top the 20's if on 2 lane highway and stay near 55-60 mph.
    Your posted fuel mileage sounds very normal for the truck you have.
    2014 F 150 Supercab XLT 4wd 3.5 Ecoboost
    Ecoboost Jr Member avwizz's Avatar
    39
    15491
    18 times
    8.5-9mpg with our 218rbsl. But Iíve got a lift and all terrains. 3.31 rear end. 12mpg sounds like a dream but you canít have it all!
    Ecoboost Regular J-Winship's Avatar
    Nov 2017
    154
    50913
    54 times
    Iím about in line with everyone else. Towing about 10k I get 8-12. Keep the hair driers off and you do ok. Thatís hard to do towing though.
    Rookie rpenn57's Avatar
    Jan 2019
    Pflugerville, Tx
    69882
    We just got back from a 6 day trip from central Texas to Mississippi and back pulling an approx 6000 lb, 24 ft TT, 11' 2" ft tall. My truck is a 2018 Supercrew F150 3.5 eco, max tow pkg with 3.55 gears. Total trip: Engine time - 38 hrs, 1476 miles, 10.6 mpg. A couple of those days without the TT while sight seeings. The trip home on the last day: Engine time - 10 hrs, 462 miles, 8.9 mpg. I mostly drove between 60-65 mph.
  1. Gas Mileage?
    By BlakeHallTexas in forum F150 Ecoboost Problems
    Last Post: 05-02-2015, 11:50 AM
  2. Tricks of the trade, how do I get better gas mileage?
    By luckysullyirish in forum F150 Ecoboost Photos/Videos
    Last Post: 02-28-2014, 10:11 AM
  3. Gas mileage drastic changes please help!!
    By 13silverECOBEAST in forum F150 Ecoboost Chat
    Last Post: 02-21-2014, 05:10 PM
  4. Weird gas mileage
    By 13TuxEco in forum F150 Ecoboost Chat
    Last Post: 01-25-2014, 02:38 PM
  5. Leveling Kit and Gas Mileage
    By NDKoze in forum F150 Ecoboost Suspension
    Last Post: 10-12-2013, 05:06 AM
f150 ecoboost gas mileage
