Need help with new thermostat
This is a discussion on Need help with new thermostat within the 2nd Gen F150 Ecoboost forums, part of the 2nd Gen F150 Ecoboost Forum (2015+) category; Ok. Iím sure there is an easy answer, does anyone have a suggestion to keep the o ring on place while I install a new ...
  • 1 Post By DNA Dan
Thread: Need help with new thermostat
    Ecoboost Jr Member Rds912's Avatar
    35
    64474
    4 times
    Ok. Iím sure there is an easy answer, does anyone have a suggestion to keep the o ring on place while I install a new thermostat.
    780
    243 times
    Quote Originally Posted by Rds912 View Post
    I just replaced mine with the super stant variety. When I shoved the o-ring up in there, it just stayed in place. I quickly put the housing back and tightened the screws a few turns at a time, alternating from one screw to the other so it would seat flush.
    Is the o-ring falling out of the hole? Is it wet? mine was dry when I did it.
    Ecoboost Veteran Grabber70Mach's Avatar
    Nov 2014
    Southern MD
    341
    6910
    79 times
    Vaseline has many uses.
    1,052
    373 times
    Mine hung in just fine. I put the thermostat in, then the o ring and it all held in place.
    Ecoboost Master ptown's Avatar
    1,458
    629 times
    Some people jack up the driver side of the truck
  1. Meth, thermostat, and downpipe install help.
    By connor65 in forum F150 Ecoboost Performance
    Last Post: 01-30-2017, 04:12 AM
  2. new 170 deg thermostat 2015 2016 3.5 ecoboost
    By donnyonee in forum Rob's Tire and Auto
    Last Post: 01-18-2016, 05:55 PM
  3. new 170 deg thermostat 2015 2016 3.5 ecoboost
    By donnyonee in forum 2nd Gen F150 Ecoboost
    Last Post: 01-15-2016, 11:41 PM
