2017 3.5 E85 testing and data round 2! - Page 2
This is a discussion on 2017 3.5 E85 testing and data round 2! within the 2nd Gen F150 Ecoboost forums, part of the 2nd Gen F150 Ecoboost Forum (2015+) category; Yea Iím not expecting much to be gained from E85 vs e50 I just get tired of having to mix at the pump. I do ...
Results 11 to 20 of 27
Like Tree11Likes
Thread: 2017 3.5 E85 testing and data round 2!
    Ecoboost Regular magyar86's Avatar
    125
    14248
    57 times
    Yea Iím not expecting much to be gained from E85 vs e50 I just get tired of having to mix at the pump. I do think it will handle the heat a little better and might be able to take a few more degrees of timing. I will keep yíall posted. Should have it on dyno this week. Iím finishing up the wiring and what not then Iíll be ready to throw it on there and start tuning.
    Ecoboost Regular biglipps66's Avatar
    Aug 2017
    Everywhere U.S.
    109
    43306
    51 times
    My brother sees as much as 21 degrees on his e50 tune, but is also running 100 octane pump to mix it. It's really only for moments at a time really, the norm is about 18-19. With my meth I'm about the same. I'm sure you guys can manage the same 20-21 with e70+, we'll also be testing this. Interested to see the rest of your build with the Gearhead turbos!
    Old school turbo guy
    17' 3.5
    Full Race - FMIC, downpipes, catback
    Precision bolt on upgrade turbos
    Water Methanol cooling sauce - ProMeth
    MPT tunes
    Ecoboost Regular w00t692's Avatar
    Aug 2017
    137
    43250
    53 times
    21 degrees of timing is past MBT. Probably going to pop the head gasket with that kind of timing. It won't knock, just lift the head probably.
    125
    14248
    57 times
    Iím headed back into town so should have truck on dyno in a few days. Not knowing what MBT timing is is main reason I havenít pushed timing and kept it around 17-18. Iíll slowly up timing till it stops making power then lower it 2 degrees for safety. Iím also going play with boost from about 14psi to 19 psi and see at what point I get diminishing returns as far as both power and heat from turbos. Right now I have it sitting at about 18psi and it seems like a good number but I want to verify on dyno.
    w00t692 likes this.
    Aug 2017
    Everywhere U.S.
    109
    43306
    51 times
    This is the only one I could dig up quick, this was a DYNO (not street) pull that hit 20 degrees. If I can find the 21 degrees graph I'll post it. Generally, he's floating between 18-19 on a very consistent basis.
    Name:  Screen Shot 2019-06-28 at 8.34.50 AM.png
    17' 3.5
    MPT tunes
    Ecoboost Jr Member avf150's Avatar
    antelope valley CA
    42
    65760
    13 times
    Just curious, does E85 affect our timing chain tensioners like on the early gt500s? or are these made from different matriel?
    125
    14248
    57 times
    Iíve been running e50 for about the last year and now will be at E85-e90 so I guess we will see if anything negative happens.
    The controller box on dyno is having issues, I will have new one tomorrow. Im going get truck bolted to dyno today and try and make a few pulls. I can still
    Run the dyno just wonít have the remote so will
    Have to control dyno through software.
    Just filled up with second tank of E85 at the Sunoco a few miles away. Their E85 always test higher than E85, this tank is about e90. Will update later
    Aug 2017
    Everywhere U.S.
    109
    43306
    51 times
    Get some data logs for me, I would love to see them!
    17' 3.5
    MPT tunes
    Ecoboost Veteran Rusty Shackleford's Avatar
    May 2018
    B.C.
    279
    62705
    117 times
    Quote Originally Posted by magyar86 View Post
    The e-85 I get tests at 90% as well. It's a nice surprise.
    2017 3.5
    Ecoboost Regular SeTXathlete14's Avatar
    texas
    203
    3911
    66 times
    pretty sure you'll be out of injector at that point. most i've seen is 80% content with a bigger in tank pump
