Fix the trans? Why dont you get a aftermarket one made thats better spec? the 2wd is always 2 piece vs 1 piece 4wd. I 100% believe my little vibration is due to driveshaft.
The driveshaft was forced into the rear of the transmission causing bearing damage. Unfortunately it's not a bearing that can be removed with the case together so trans has to come out, case split, bearing R&R'd and then put back together and in the truck.
Hi everyone I'm new on the forum I just buy a tremor fx4 ... and is missing the driver side running board anyone is interest it on selling me the running board by any chance? Thanks
I love the look in that first picture. Was the damage caused from that initial drop or the 3/5? Been eyeing a 3/5 drop for mine - coming from a 3/4 dropped ranger this truck sits way to high for my tastes. I didn't have any issues with the DJM 3/4 on my '98 or '2006 Ranger - not seeing a lot of reports about transmission damage for a 3/5 on an F-150. Assuming this was due to the extreme drop you had initially? Just want a bit of clarification before I have a ton of damage I wasn't expecting to have to account for!
Hey Qazme, I did a 3/4 on mine, DJM arms in front with a Belltech flip kit in the rear, and the ride is great on it. I went with the 4 in the back because our trucks can look too low in the back when they are really "level". Mine has just a "touch" of forward rake.
I haven’t seen any reports of damage like this from 3/5 drops or even lower. I talked to Tony at Belltech also asking him about this issue and he has not heard of it either. I’m still not sure how this happened to you. I have a 3.5/5 drop now and looking to go lower and I’m investigating because I don’t want any issues. Do you have any pictures of the driveshaft set up you had made?
F150Ecoboost.net is the best Ford F150 Ecoboost Forum with discussions on 2011+ F150 Ecoboost Trucks. Discuss performance mods, towing questions, wheels, tires, lift kits, and much more!
