How to mod AC to blow COLDER - Page 14
This is a discussion on How to mod AC to blow COLDER within the F150 Ecoboost Guides and How-Tos forums, part of the F150 Ecoboost Garage category; Originally Posted by DNA Dan Whoa there. I appreciate the concern. Thank you for the clarification. I did read that long thread believe it or ...
Page 14 of 14 FirstFirst ... 4121314
Results 131 to 132 of 132
Like Tree44Likes
Thread: How to mod AC to blow COLDER
  1. #131
    Ecoboost Jr Member digitaltrucker's Avatar
    Sep 2015
    Texas
    24
    13318
    8 times
    Whoa there. I appreciate the concern. Thank you for the clarification. I did read that long thread believe it or not. I also read the thread over at f150forum. I have several resistors from 200k to 1000k ohm. My confusion is what Trev just recently posted. He uses a 360K ohm and was showing ~38 degrees. When he goes up to 380K his temp is showing ~36 degrees. So is it more ohms lower temperature? or more ohms higher temperature? From your comments I assume I should start with the highst Ohm resistor that I have, correct?
    I am no scientist, electrician or geek! You do any of this at your own discretion and risk! All I can tell you is that these trucks are all different! Have not seen any 2 trucks act the same with the same resistor. Having said that, I would suggest a 1 meg pot switch, which you can adjust up and downward to test for your system. If you go this route, set it with a multi meter, then install. The donor truck I reference on the other forum has one and is currently dialed in around 370. Rarely does the donor truck ever use recirc or max! Remember, it may take some trial and error. You need to drive it a while for it to sync in with the resistor on the Temp Probe in the evap coil.
    2013 F150 Lariat, with NO AC!
  2. #132
    Ecoboost Veteran trev's Avatar
    Lower Mainland, BC
    455
    7617
    140 times
    Stock i was cycling between 41-45*F
    With 360K Ohm i was cycling between 35-40*F
    With 380K Ohm i was cycling between 36-41*F
    Those tests were done with a potentiometer and a fluke meter to verify resistance. I have since settled with using a 400k Ohm resistor.
    Lower Ohms will result in colder temps. Higher Ohms will result higher temps.
    I would recommend starting out with 400k ohm. I would also strongly recommend you monitor AC parameters with Forscan (not required but makes it really easy to see when the compressor is cycling on/off).
    Testing Ohm range should be between 320-420k Ohms. Every vehicle is different so you will have to test and determine the best resistance for yourself.
    2014 FX4 screw, max tow, 3.73, 402a, 5.5', Unleashed 91 & 93, Wagner CAC, solo res DP's, DO water meth inj, Helwig RSB, Bilstein 5100's, 275/60/20 Duratracs, Blizzak DMV2's (winter)
  1. DIY blow off valve
    By Greg in forum F150 Ecoboost Performance
    Last Post: 06-15-2018, 07:03 AM
  2. Blow off valves
    By usmarine475 in forum F150 Ecoboost Performance
    Last Post: 05-21-2015, 02:41 PM
  3. Colder plugs NGK?
    By T-boxFX4 in forum F150 Ecoboost Performance
    Last Post: 12-23-2014, 02:08 PM
  4. Blow off valve
    By eric68 in forum F150 Ecoboost Maintenance
    Last Post: 08-07-2014, 05:17 AM
  5. Air Bag Blow out?
    By wildweasel7648 in forum F150 Ecoboost Towing
    Last Post: 08-11-2013, 12:27 PM
2010 ford f150 compressor cycling fix
2013 f150 ecoboost evap canister
an air conditioner mod
compressor cycling fix on ford f150
ford ecoboost hack
how to get f150 ac to blow colder
how to make 2012 f150 ac colder
troubleshooting 2012 f150 air conditioning
