My 170 degree thermostat install write up. - Page 15
This is a discussion on My 170 degree thermostat install write up. within the F150 Ecoboost Guides and How-Tos forums, part of the F150 Ecoboost Garage category; Sent from my iPhone using Tapatalk...
Page 15 of 15 FirstFirst ... 5131415
Results 141 to 145 of 145
Like Tree51Likes
Thread: My 170 degree thermostat install write up.
  1. #141
    Rookie stevetheman's Avatar
    May 2017
    19
    35057
  2. #142
    May 2017
    19
    35057
    Is there benefit or downside of swapping to thermostat to 170 of you don't have a tune - just running bone stock ?
  3. #143
    Ecoboost Jr Member JaDO81's Avatar
    Fort Worth, Texas
    46
    14808
    Thank you for the great write-up. The work was relatively painless and only took 25 minutes or so. Before I started, I was a bit worried, as my t-stat only came with an O-Ring, and someone here (forgive me for not recalling your username) showed a gasket that would slip over and cover (like an old chevy 350 gasket) both sides of the thermostat, however, it was exactly like the one that came out with the old thermostat.
    My temps have gotten as high as 200, heat is blowing out of the vents, everything is topped off, but I'm not hearing fans come on yet. I've got an updated tune that I'll load later this evening and hopefully that should have the fans come on. As it sits now, it won't get over 200, even if I'm revving it to 3k.
    As an FYI, the orange Motorcraft coolant at O'Reilly's is about $35. Way more expensive than just 'Orange Antifreeze'. I hope it's worth it for the Motorcraft stuff, but like someone said, "It's a $50k truck, why cheap out with crappy antifreeze.
    2013 SCREW 502A Lariat. 3.15's. 5* Tuned, 170 Tstat, Drilled CAC, removed CAC plates. LEDs all around.
    Rom. 8:28
    Gal. 2:20.
  5. #144
    AB
    338
    36866
    149 times
    Prestone Dex-cool has Ford certification for the coolant, WSS-M97B44-D2. Use it without concern:
    https://www.autozone.com/antifreeze-...ant/672816_0_0
    Quote Originally Posted by JaDO81 View Post
    -2019 Open Range UT2504BH.
    -Sold: 2010 Funfinder 189FDS
  6. #145
    Eco-Beast ptown's Avatar
    1,619
    688 times
    Quote Originally Posted by TCP2 View Post
    X2 thatís what I run
  1. Lower thermostat temp?
    By whaines944 in forum F150 Ecoboost Performance
    Last Post: 10-15-2017, 01:00 PM
  2. Spark Plug Installation Write-Up?
    By SickStroke6.0 in forum F150 Ecoboost Maintenance
    Last Post: 05-25-2014, 07:51 PM
  3. MPG with 170 thermostat
    By jmfmk3 in forum F150 Ecoboost Performance
    Last Post: 03-08-2014, 07:19 PM
  4. Great New write up about the SCT livewire for F150 Ecoboost
    By Stage3Motorsports in forum F150 Ecoboost Performance
    Last Post: 08-17-2013, 01:21 PM
  5. 170* Thermostat
    By MATTWAYNE07 in forum F150 Ecoboost Performance
    Last Post: 12-14-2012, 12:57 PM
170 degree thermostat ecoboost
ecoboost 170 degree thermostat
ecoboost thermostat
ecoboost thermostat install
f150 ecoboost 170 thermostat
f150 ecoboost 170 thermostat installation
f150 ecoboost thermostat
f150 ecoboost thermostat install
