How to repin coil on plug (COP) connections, pigtails
This is a discussion on How to repin coil on plug (COP) connections, pigtails within the F150 Ecoboost Guides and How-Tos forums, part of the F150 Ecoboost Garage category; Bare with me...descriptions coming when I get on the laptop but figured I'd upload the pictures while I was thinking about it. Sent from my ...
  • 1 Post By ptown
Thread: How to repin coil on plug (COP) connections, pigtails
    Eco-Beast ptown's Avatar
    1,626
    693 times
    devin likes this.
    Ecoboost Veteran devin's Avatar
    Aug 2016
    Pacific Northwest
    415
    19409
    107 times
    Waiting patiently.
    Devin
    Sold it! No truck for now.
    1,626
    693 times
    Quote Originally Posted by devin View Post
    Waiting patiently.
    Long story short..pop white piece out front, pop black piece out back, depress pins to allow them to pull through. The most critical part of this whole thing is applying adequate upwards pressure on the pin keeps. You should be able to do as I did in the picture and hold it with one hand while you push the pin through. If not you do not have enough pressure!! Slide a flat blade in and pry towards the pin itself (lifting up on the tab inside) I used a square head bit to push the pins through. If they don't go fairly easy STOP. If you're doing it correctly they slide easy. If not, you'll f*ck it up. Do not put anything inside the pin! Find the right OD 'tool' to press on the outsides of the pin
    Olathe Ks
    765
    14790
    215 times
    Just out of curiosity, why would one want/need to re-pin the coil connection?? Not being a smartass but just want to learn.
    ~Jim~
    2012 Lariat Screw 3.5L; 4x4; 3.55 E-Locker; Lux/Tow Package;
    Exhaust; 3" Resonator Delete;Turbosmart BOVs; Bilstein 5100s; Leveled; 20% Window Tint; Full Interior LEDs; PIAA Heads/Fogs; Forscan; BFG 275/70/18 KO2s
    1,626
    693 times
    Quote Originally Posted by MudnRox View Post
    If you broke the retaining clip and are anal about having it working as originally designed.
  1. MSD Blaster On-Coil Plug Kit Review
    By Ducatti20 in forum F150 Ecoboost Performance
    Last Post: 07-10-2017, 05:01 PM
  2. Coil On-Plug Change
    By meaz93 in forum F150 Ecoboost Problems
    Last Post: 04-27-2017, 07:45 AM
  3. Spark Plug (Coil-On-Plug) Boots at RockAuto.com!
    By RockAuto in forum RockAuto.com
    Last Post: 01-12-2017, 11:03 AM
  4. Ecoboost Vs. Cop Car
    By Rutt3.5 in forum F150 Ecoboost Racing
    Last Post: 04-08-2016, 07:06 AM
  5. high knock, bad gas, spark plug coil
    By spence08 in forum F150 Ecoboost Performance
    Last Post: 05-30-2014, 09:43 PM
