2011 - 2014 UPR F150 Ecoboost Dual Valve Catch Can w CSCC™ Installation Plug n Play™
This is a discussion on 2011 - 2014 UPR F150 Ecoboost Dual Valve Catch Can w CSCC™ Installation Plug n Play™ within the UPR Products forums, part of the Vendors category; This installation was performed on a 2012 3.5L F150 Ecoboost truck with a UPR pre-drilled passenger side inlet tube for the WOT connection. This is ...
Results 1 to 10 of 12
Thread: 2011 - 2014 UPR F150 Ecoboost Dual Valve Catch Can w CSCC™ Installation Plug n Play™
    Sponsor UPRjoe's Avatar
    Nov 2013
    United States
    435
    2972
    221 times
    passenger side
    This is a very clean and easy installation for a novice and you really don't have to be very mechanically
    inclined to be able to install a UPR Plug n Play™ Dual Valve Catch Can System with CSCC™ as this video
    clearly, shows just how easy the system can be installed.
    The longest part of the installation is the installation of the UPR pre-drilled turbo inlet pipe. The inlet tube
    requires you to remove the lower clamp at the
    turbo and the upper clamp at the Y pipe top center of the
    engine bay and will take 20min.
    This will be listed on the UPR Website tomorrow.
    Joe
    Rookie Perferd's Avatar
    Feb 2017
    10
    29193
    Very well done thank you.
    Sorry if silly question but how are the cc's emptied?
    Ecoboost Jr Member Wildroamer's Avatar
    Feb 2017
    Vermont
    22
    29625
    I'm curious about that as well. Looks pretty tight in there. Also wondering how this differs from those already on your site.
    Looks great, likely will be ordering soon!
    Nov 2013
    United States
    435
    2972
    221 times
    2011 - 2014 UPR Plug n Play™ F150 Ecoboost Dual Valve Catch Can with Clean Side Catch Can
    This system is very easy to drain as it incorporates a high flow UPR 1/4 Turn Drain Valve.
    It takes longer to put a bucket under the truck than it will to reach the drain valve and turn it to empty the catch can.
    For the CSCC™ you only need to press or squeeze the UPR Plug n Play™ Fittings to release the lines and then you unscrew
    the bottom of the Clean Side Catch Can and can neatly remove it to be drained.
    This entire draining process will take you about 3-5 minutes if you take your time.
    Joe
    Feb 2017
    Vermont
    22
    29625
    CSS vs CSCC?
    Nov 2013
    United States
    435
    2972
    221 times
    Quote Originally Posted by Wildroamer View Post
    CSS vs CSCC?
    I have updated the listing in the drop-down box to offer both kits.
    Here is the link to the new kits for the 2011-2014 engine bay mounts UPR Plug n Play™ Dual Valve Catch Can with the UPR Plug n Play™ CSCC™
    11-14 F150 Ecoboost 3.5 Dual Valve Catch Can CSS CSCC
    5030-118-CSCC 2011 - 2014 UPR Plug n Play™ F150 Ecoboost Dual Valve Catch Can w CSCC™ Installation (Satin)
    5030-118-1-CSCC
    2011 - 2014 UPR Plug n Play™ F150 Ecoboost Dual Valve Catch Can w CSCC™ Installation (Black)
    PM, me for an introductory special offer on these brand new systems.
    Joe
    Nov 2013
    United States
    435
    2972
    221 times
    CSS vs CSCC?
    The instructions for draining refer to the UPR Plug n Play™ CSCC™ as the UPR Plug n Play™ CSS does not require maintenance.
    Feel free to PM me.
    Joe
    Feb 2017
    10
    29193
    So the difference now is the added option in the drop down box to choose the cscc for an additional $50 going from 400 to 450. With that we now have the most up to date ultimate package?
    I guess you can add the valves for 35 or 70 as well...
    The mega can you can add the same option of cscc for 50?
    If someone already has the system can you just purchase the cscc for 50?
    Ecoboost Pro waterbuffalo's Avatar
    947
    22266
    365 times
    Just pm'ed you. Waiting for your response.
    Thanks brian.
    Sent to you using my stupid Iphone
    Nov 2013
    United States
    435
    2972
    221 times
    Brian,
    just replied
    Joe
  1. Replies: 0
    Last Post: 02-23-2017, 01:19 PM
  2. Replies: 52
    Last Post: 12-28-2016, 10:21 AM
  3. Replies: 1
    Last Post: 11-18-2014, 02:34 PM
  4. Replies: 4
    Last Post: 10-19-2014, 09:24 AM
upr dual side catch can f150 ecoboost 2011
