2012 Ecoboost enging noise at start up
This is a discussion on 2012 Ecoboost enging noise at start up within the F150 Ecoboost Chat forums, part of the F150 Ecoboost Forum category; I have a 2012 F150 Ecoboost with 12,000 miles and about 2 weeks ago I started to get a engine noise. The noise sounds like ...
Results 1 to 10 of 10
  • 1 Post By OxfordFX4
Thread: 2012 Ecoboost enging noise at start up
    Rookie brberno's Avatar
    May 2014
    Michigan
    5
    5060
    I have a 2012 F150 Ecoboost with 12,000 miles and about 2 weeks ago I started to get a engine noise. The noise sounds like when you hear a vehicle that's brakes are shot and you have metal on metal grinding / rubbing when you apply the brakes, if that makes sense. The noise usually lasts for about 5 seconds. I took the air cleaner cover off because that is where the sound is coming from the loudest. I am quite certain it is one of the turbos but usually only does it a start up, although I did hear it once after I had stopped the truck and was backing up. Wondering If anyone else had this problem and what It was. Thanks
    Eco-Beast OxfordFX4's Avatar
    Sep 2013
    Iowa
    2,598
    2267
    1120 times
    Are you sure it's not just the turbos spooling a little when you start the truck? They do make a high pitched noise....
    compman72 likes this.
    2013 F150 FX4 SuperCrew Cab Traded on a 2014 Mustang GT Track Pack
    Eco-Beast agentjohnson's Avatar
    East Texas
    3,883
    4749
    1508 times
    Yeah I freaked over turbo noise, on colder days it sounds like the truck is getting ready to head into orbit for the first few minutes of idle..... Never a metal on metal noise though, kinda lame to ask, but are you keeping up with your oil level?
    peon
    Banned Tuner Boost's Avatar
    Dec 2013
    Sunshine State
    1,173
    3153
    561 times
    Any of the tensioner or idler pulley's can make a similar sound if the bearings are going also, and that would be an easy fix. Have someone listen at the engine bay when it's started and try to pin-point just where it is coming from. Ford service center will be able to as well
    May 2014
    Michigan
    5
    5060
    I took the air cleaner box cover off, its definitely a noise coming from down by the turbos. Oil levels are good, just changed about a month ago. Since only 12K miles on it, it will be going to the shop for warranty work. If it is the tubos, it won't sit well with me that one went so soon.
    Ford Customer Care FordService's Avatar
    1,028
    4446
    246 times
    Quote Originally Posted by brberno View Post
    brberno,
    It certainly wouldn't hurt to have the dealer take a look. Send me a PM with your name, phone number, VIN, mileage, and dealer info. I'll lend a hand.
    Ashley
    May 2014
    Michigan
    5
    5060
    Ashly, It is scheduled for Tuesday. I also have them checking out two other problems I'm having. One is the "Shudder" when towing a load, seems to be a problem that Ford don't have a solution for on the SuperCrews with the 6.5' box. Second is the display for Miles to Empty that fluctuates back and forth or wont move at all for many miles at a time. Thanks for the heads up on help, if it don't get the proper attention at my dealership next week, I'll let you know. Ben
    1,028
    4446
    246 times
    Sounds like a plan, Ben. Just let me know!
    Ashley
    May 2014
    Michigan
    5
    5060
    Truck is in the shop today. They couldn't find the turbo noise until I called and told them to open the hood and listen when it starts because it only lasts 5 - 8 seconds. They then heard it and now have a call in to Ford Tech I guess to try and find what it may be since they don't know....go figure. Second thing is the shudder I have from a dead stop when pulling my travel trailer. They didn't know what I was talking about there either, I spelled it out that its all over the forums as either axle wrap or driveline shudder on the Supercrew Ecoboost with 6.5 box. They said they did a transmission update dia update. Hmmmm don't think that will fix the problem. Won't even bring up the instrumentation problem that its also in there for. Lots of problems on a $46.000 truck and not even 12,000 miles on it yet.
    Ecoboost Regular Zx12-iowa's Avatar
    May 2014
    108
    5176
    32 times
    Any news on this? I just started getting a Wierd noise on start up. Approaching 37k miles so I may be screwed if it's pricey. My noise is also only a few seconds after start up and is very loud.
  1. 2012 ecoboost grinding noise from engine
    By redboost in forum F150 Ecoboost Problems
    Last Post: 07-06-2017, 05:09 PM
  2. Clunking Noise in Drive Train 2012 EB 4X4
    By xjaywalker in forum F150 Ecoboost Problems
    Last Post: 10-26-2015, 08:40 PM
  3. Ecoboost Noise on cold start from front left area
    By hiltonmj in forum F150 Ecoboost Chat
    Last Post: 09-19-2014, 04:06 PM
  4. EcoBoost cold start issues
    By jessekf in forum F150 Ecoboost Problems
    Last Post: 04-08-2014, 05:42 PM
  5. 2012 Ecoboost Fan noise over 20mph
    By FFPM03 in forum F150 Ecoboost Problems
    Last Post: 02-11-2014, 07:36 AM
2011 ford f150 grinding noise when starting
2012 ecoboost noise coming from turbos
2012 f-150 ecoboost engine noise
2012 f150 ecoboost noise after startup
2012 f150 ecoboost noise after strartup
2012 f150 grinding noise on start up
2012 f150 lecoboost loud noise on cold startup
f150 tensioner noise ecoboost
