Looking for a tacky rubber spray.. - Page 3
This is a discussion on Looking for a tacky rubber spray.. within the F150 Ecoboost Chat forums, part of the F150 Ecoboost Forum category; What about grip tape? I had to add strips of it over the raised rubber strips on my oem running boards. Wife kept falling out ...
Results 21 to 30 of 34
Like Tree11Likes
Thread: Looking for a tacky rubber spray..
    Ecoboost Regular R0bCincy's Avatar
    Cincinnati, OH
    182
    59570
    51 times
    What about grip tape? I had to add strips of it over the raised rubber strips on my oem running boards. Wife kept falling out of the truck.
    2011 FX4 SCREW, 3.5 EB. 3.73 and 5* and MPT Tunes, SW catted DP and SW 3.5 inch Chambered Exhaust, AFE Stage 2 Intake, Mishimoto CAC, and very rusty cab corners.
    Cincinnati, OH
    182
    59570
    51 times
    Or just scuff the finish with a wire wheel
    1,035
    364 times
    https://armorpoxy.com/armortrak-flex...thane-coating/
    ArmorTrak is a tough, single-pack, totally flexible, slip-resistant, waterproof protective urethane coating. ArmorTrak will chemically bond to most clean and dry surfaces. It works as a rubberized paint for wood, concrete, fiberglass, metal, rubber, sound-painted materials and more. Some metal and extremely porous surfaces may need to be primed. ArmorTrak can be applied by roller, brush or spray. ArmorTrak can give a relatively smooth or rough surface, depending on application technique.
    Minimum I can spend to order is $300 lol. That may have to wait a bit
    Gearhead Tuned
    Wagner CAC - Accel Copper Plugs
    Bilstein 5100's
    4,055
    3133 times
    @Envious, regardless of what method you attempt, I will offer a small tip if you are going to spray or adhere anything to your mats:
    The plastic is a petroleum based compound will will "off-gas" ever so slightly for the life of them. It's just what happens (that's why you develop the light film on the inside of your windshield-even if you're a non-smoker)....To help anything stick, clean them good with rubbing alcohol, warm the mats up really well (hairdryer) and then apply whatever it is to them. This will really strengthen the adherence.
    1,035
    364 times
    Appreciate the tip. I have an abundance of IPA and use it to clean everything lol So we will be good on that. I have a heat gun as well so I will try not to go to crazy with that
    Elmore328 likes this.
    Gearhead Tuned
    Bilstein 5100's
    Ecoboost Sr Member jag1886's Avatar
    Jan 2018
    Boise Idaho
    93
    53650
    34 times
    Just sand them a little with some 100 grit sandpaper, no more slippery
    2011 XLT 3.5 ECOBOOST 7700 GVWR MAX TOW 3.73 GEAR
    Ecoboost Regular Bubbabiker's Avatar
    May 2018
    Texas
    171
    63018
    27 times
    I have a set of these rubber mats in my truck. Decent for the price and fit well.
    https://www.ebay.com/itm/Floor-Mats-...oAAOSwfVpYp8wG
    2016 F-150 SuperCrew FX4 2.7L
    1,035
    364 times
    Quote Originally Posted by Elmore328 View Post
    My company (Blue Magic) makes this exact product and it's a really good product....but I don't know that it will be grippy enough and might leave you disappointed. Send me a PM with your physical mailing address and I'll send you a can to try. That way if it doesn't turn out like you hoped, it wouldn't be a waste of money.
    Thanks! I got it in the mail and im still alive
    It does look good when it warms up i am going to give it a try and see what it looks like! Thank you for the care package haha
    Gearhead Tuned
    Bilstein 5100's
    6,539
    2613 times
    Shoulda bought huskies?
    Mine have been great and never slipped once!
    Sent from my SM-G870W using Tapatalk
    1,035
    364 times
    Quote Originally Posted by winchested View Post
    Someone else said they are slippery. Do you have the back mats?
    If you set a hard plastic toolbox in the back will it slip n slide all over?? lol I had the ball joint tool case I rented in the back and took a SLOW turn and it slammed into my door panel in the back.
    Gearhead Tuned
    Bilstein 5100's
  1. LineX or Rhino spray in bed liner?
    By Wags 2237 in forum F150 Ecoboost Accessories
    Last Post: 02-01-2015, 08:53 AM
  2. 3m Paint Defender Spray Film
    By blancoh2o in forum F150 Ecoboost Appearance
    Last Post: 01-03-2015, 09:16 AM
  3. Spray in bed line's
    By hale0522 in forum F150 Ecoboost Appearance
    Last Post: 05-16-2014, 03:03 PM
  4. Spray in Liner colour matching?
    By Eco-Beast_1308 in forum F150 Ecoboost Builds
    Last Post: 09-19-2013, 02:13 PM
  5. Factory Spray-In Bed Liner + BedRug?
    By slaveoftems in forum F150 Ecoboost Chat
    Last Post: 08-13-2013, 10:30 AM
