Complete F150 & Raptor A-Pillar Package with Brackets and Rigid Off-Road LED Lights
The only thing better than adding a set of A-Pillar Brackets and high-quality off-road LED lights to your tough F150 or Raptor build is when you can get both all in one place. That's why we put together our very own A-Pillar Package with Grimm Offroad A-Pillar Brackets and a pair of Rigid Industries Dually Pro Spot beam lights so that your F150 or Raptor gets some serious off-road lighting capability in a clean, mean, low-profile package. Our A-Pillar Light Package is an excellent way to get awesome forward lighting with long range so that you can see obstacles and problems down the trail before your evening or night gets ruined. The Grimm A-Pillar Brackets are extremely easy to install while the Rigid Dually Pro Spot beam lights come with wiring and drop right onto the Grimm brackets without the need for any drilling, trimming, or other modifications.
A-Pillar Brackets with Heavy-Duty Steel Construction with Black Powder Coat Finish and Drop-in Install
Grimm carefully designs each of their cowl brackets for a perfect fit and flawless positioning of the lights next to your truck's A-pillars and builds them out of extremely strong materials so that they can survive the toughest off-road challenges. Each bracket is made out of 11-gauge steel that's laser-cut and CNC formed. The brackets drop into your F150 or Super Duty's fender mounting bolt using the OEM hardware, making them easy to install. The brackets are topped off with a semi-gloss black powder coat finish that gives them a great look that fits in with practically any OEM paint color or aftermarket styling theme while also protecting the steel from corrosion. The brackets are proudly made in the USA and come backed by a limited lifetime warranty.
10° Spot Light Beam Pattern with Huge Range
Each spot light unit in this pair feature four powerful LEDs arranged in a 2x2 pattern. Rigid's patented Hybrid Optics system utilizes a combination of lens and reflector to maximize the amount of light emitted from the LED, allowing you to project it exactly where you want it. It casts a beam in a 10 spot pattern producing a narrow, but intense beam of light over a long distance. With such a precise range of the spot beam your F-150 or Jeep will have no problems picking up trail hazards and other problems during high-speed or off-road runs. The Spot Duallys are a great addition to any off-road vehicle or truck that needs to see way down range after the sun goes down. The LEDs and optics are protected by a durable aluminum housing and thick polycarbonate lenses that allow them to survive practically any application on or off road.
