1 - 10 of 10 Posts
Does anyone know if there were any diff w/ the 13 eco 3.5 engines and 14’s? When searching motors for my 14 I’m seeing the question thru 12/15/13 and from 12/16/13. I’m trying to find out if there were any major diff in the 2. I’m sure there has to be some sort just not sure what. Any help with this?
I’m not positive... but I believe 14 is a Gen 2 motor.
2013 F150 XLT 3.5L SCrew. AFE Magnum Force Stage-2 Dual 3-1/2" CAI, Mishimoto Performance Intercooler with Pipes, TurboSmart SP Supersonic BOV Kit , Team RXP Heat Exchanged Dual Catch Can, AEM Coil Packs, SCT/Bully Dog BDX Tuner w/5* Tuning Custom Tunes, AFE Atlas 4" Aluminized Steel Cat-Back
No the gen 2 started in 2017
I stand corrected! Thank you sir!
I don’t think so. Nothing major internal. The 13’s have bigger turbos than the 12’s
Wasn’t sure if there were any diff to the setup. Blew mine completely apart. Starter was even blown off bell housing so thinking trans as well. But everywhere I search, I get was build date before 12/15 or after!! Been researching and can’t find anything. Seems like the 15’ engines work w the 14’s if build date is after 12/15. There’s a lot more of these out there w low mileage and want to try going that route if I’m able to without major diff between the 2.
I’m sure somebody on here knows what needs to be done when putting in different year motors, I think it’s more of a pcm issue.
The only difference I can think of between the 13 and 14 trucks is the front shock absorber mounting.
Sent from my moto g(6) play using Tapatalk
They are completely interchangeable. I’ve seen a few folks replace motors and not have any issues between a 2013 and 2014.
1 - 10 of 10 Posts
