What's wrong with 205 coolant temp ? Nothing.The 180 which installed in feb/March usually ram 195-205 all the time. I thought it was defective and went with another 180 form rock auto and still got same temps.
If you running lower rpm’s with a bigger opening for the water pump to flow coolant through vs a smaller one might help with running temps.The 160 is fully open and X temp and the 180 is fully open at X temp. That doesn't determine what temp the engine ultimately gets to.
If that’s the case, you’ll likely only see a temp shift at hwy speeds without the fans adjusted.Nope. Not unless my tuner guy did it but I’m pretty sure he left all that stock
The 'system' aint gonna keep temps where he wants in Summer temps regardless of fans unless his Summer temps are 80's.If that’s the case, you’ll likely only see a temp shift at hwy speeds without the fans adjusted.
The thermostat will open at the right temp, but the system isn’t going to keep the temps down without the fans coming on.
This, exactly. My towing temps didn’t drop until I got my Mishimoto radiator. Now they will hang in the low 200’s with a 180F thermostat. I suspect a lower temp stat may allow me to run slightly lower than that. But not much.If the cooling stack could actually shed heat fast enough, a lower thermostat would hypothetically lower the operating temperature.
However, it's pretty evident that isn't the case with these trucks.
I do find it interesting though that Ford decided to make whatever changes they made to lower the normal operating temperature for the Gen3 3.5
208-216F was the normal operating temperature for the Gen2. Summer or winter the truck ran in that range dead reliably. It's what Ford wanted! (so yea, @Arkansas Eco , nothing wrong with 205)
But the Gen3 runs 188-198F
And ironically, Ford raised the transmission temp to 205-215, so the transmission runs warmer than the motor. Although it takes almost 20-25 miles to get the tranny to 200F, so some folks will never or rarely reach it.
