1 - 4 of 4 Posts
Hi all..
My back up can has gone nuts.. it still "works" but the colors are very dark and almost negative, very hard to see, and the screen is jittery.. kind of like the old security cameras you'd see on "Cops". Any ideas?
Have you disconnected the connector at the tailgate and verified it is clean? most likely not the issue but one of the easiest checks you can do.
Sent from my Pixel 3a XL using Tapatalk
2013 Screw XTR BCB Tuned
My aftermarket back up camera did that once awhile back. It was a bad ground. Ended up being my dummy move, but like ITTOG said, connector ie: the ground would be my guess also.
I did check the connector under the bed, but not in the tail gate yet. Will check that tonight
1 - 4 of 4 Posts
