Did you get the one with the 1 in block for the rear and the shocks? That's the one I have. And I have 20x9 with 33s and there is definitely room for 35s. That's what I will be purchasing soon.just recently added the rough country 2.5 leveling kit to my 2013 f150 4x4 crew cab xlt. the truck has the factory 17s. kit says it can clear up to a 35x12.50 with the stock wheels. is this true? if so will be purchasing the mickey thompson baja MTZ radials this week. thanks
<img src="http://www.f150ecoboost.net/forum/attachment.php?attachmentid=8551"/>
Yea i got the one with the rear shocks and 1 in block. But I haven't put it on yet just the front ones. And my truck sits level all the way around.I did not purchase the one with the block and 2 shocks in the rear, just the extensions up front. looks like i will be ordering the mickey thompson 35x12.50s then
Sweet kit. Im so jealous that no one has troubles but me!!!just recently added the rough country 2.5 leveling kit to my 2013 f150 4x4 crew cab xlt. the truck has the factory 17s. kit says it can clear up to a 35x12.50 with the stock wheels. is this true? if so will be purchasing the mickey thompson baja MTZ radials this week. thanks <img src="http://www.f150ecoboost.net/forum/attachment.php?attachmentid=8551"/>
I have a horrible clunk over bumps. Hopefully i can fix this week!The only issue I had was getting the nuts off the ball joints lol they aren't cotter pinned in these nuts from the factory have that plastic lock on the inside of the nuts
That nut can't be tight all the way then .that happend to me on a car one time. And had to zip it tight with a impact.I have a horrible clunk over bumps. Hopefully i can fix this week!
Maybe. Checked everything. Only thing left is the three bolts on the factory strut that go into the spacer.... # fingers crossed lolThat nut can't be tight all the way then .that happend to me on a car one time. And had to zip it tight with a impact.
What he said^^^ lolYou can remove it with a wrench lol... Or heat it up for a second and it will come off easy. The nut is a nylock nut and the plastic helps to ensure the nut won't back off once installed. The nuts generally shouldn't be used again as the plastic is spread.
got ya. So does everyone buy new nuts for the install?You can remove it with a wrench lol... Or heat it up for a second and it will come off easy. The nut is a nylock nut and the plastic helps to ensure the nut won't back off once installed. The nuts generally shouldn't be used again as the plastic is spread.
