Hey guys, I gathered some info on how to replace the turbos on your 15-17’ f150 2.7 and I think it could apply to the 18-20’ 2.7 as well.
I could not find any info on this anywhere, but finally did, and I thought I’d share it here so that someone else like me can readily find it.
Here’s a video that I found extremely helpful
Here’s a part list of things you need to replace. Of course I’m not replacing with a stock turbo, but If you are wanting to, the part number is there.
Just plug each part number into Tascaparts website and you’ll find everything.
Left Turbo
1. FL3Z6K682D Turbocharger Asy
2. W520514S440 Nut- down pipe (2)
3. W707753S900 Stud- down pipe (2)
4. JT4Z9T516A Tube Assy- oil feed tube w filter (1)
5. FT4Z6N652F Gasket (1)
6. FL3Z9448B Gasket (2)
7. FT4Z6N652D Gasket (2)
8. FT4Z6N652G Gasket (1)
9. W716383S437 Stud- turbo mounting (2)
10. FT4Z6N652E Gasket (1)
11. W714870S430 Nut- turbo mounting (2)
12. W716117S437 Bolt- turbo mounting (1)
13. FL3Z5C226A Gasket- down pipe turbo (1)
Right Turbo
1.FL3Z6K682E Turbocharger Asy
2.FL3Z5C226A Gasket- downpipe (1)
3.W520514S440 Nut- downpipe (2)
4.W707753S900 Stud- downpipe
5.FL3Z9448B Gasket (1)
6.FT4Z6N652F Gasket (1)
7.W714870S430 Nut turbo mounting (2)
8.W716383S437 Stud- turbo mounting (2)
9.W716117S437 Bolt- turbo mounting (1)
10.JT4Z9G440A oil feed Tube Assy w o rings and filter
11.FT4Z6N652E Gasket (1)
12.FT4Z6N652D Gasket (3)
Left Turbo
Right Turbo
