2" front level - before and after pic
2625 Views 7 Replies 5 Participants Last post by  Moab Junky
2
I just put a 2" puck level on my 2018 Lariat. The spacer actually measures 1.75" thick and it raised the front 1.75". I installed the exact same MotoFab spacers on my 2016 a few years back. My 2016 sat level, my 2018 still has a slight rake but it also has a max trailer tow package so maybe that's the difference. I never even aligned the 2016 and drove it that way for 107k miles with no issues. I probably won't bother aligning the 2018 either. Both trucks ride and drive just like stock afterwards. I did it by myself in my garage with hand tools. Took me about 3 hours because I worked slow and triple checked everything.
Before and after the front level...
Wheel Tire Car Automotive parking light Vehicle
The 2018 (white) versus the 2016 (black). Both have 2" MotoFab spacers...
Wheel Tire Automotive parking light Car Land vehicle
See less See more
Reactions: 1
1 - 8 of 8 Posts
A max tow 2018 will have a different leaf pack in the rear. The bumped the 2018 max tow to a 4050 lb rawr and stiffer springs which is probably the difference you are seeing.
Plus if you had a 2.7L before then the springs were even softer than a 3.5 i believe
Reactions: 1
Yea, that makes sense. Thanks for the info !
I just put a 2" puck level on my 2018 Lariat. The spacer actually measures 1.5" thick and it raised the front 1.75". I installed the exact same MotoFab spacers on my 2016 a few years back. My 2016 sat level, my 2018 still has a slight rake but it also has a max trailer tow package so maybe that's the difference. I never even aligned the 2016 and drove it that way for 107k miles with no issues. I probably won't bother aligning the 2018 either. Both trucks ride and drive just like stock afterwards. I did it by myself in my garage with hand tools. Took me about 3 hours because I worked slow and triple checked everything.
Thoughts of removing the rear block, I did to erase the slight rake after installing a 2" front leveling kit.
As long as you never carry a real heavy load. Although... I put 2166 lbs in my bed the other day and it didn't squat down as much as I thought it would.
Wheel Tire Vehicle Sky Car
See less See more
Reactions: 3
I have air bags so not too concerned
Reactions: 1
Great before and after pics. Never in a million years did I think I'd see a 2.7 in a half Ton.
Crazy the power they get out of these tiny v6's.
Thanks for the info.
Reactions: 1
1 - 8 of 8 Posts
