1 - 1 of 1 Posts
Limited qty in stock in both black or bronze
Message me for forum pricing.
Frank
2004-2021 F150 Method 20x9" NV Wheel (Matte Black) MRWMR30529016518
2004-2021 F150 Method 20x9" NV Wheel (Bronze w/ Black Lip) MRWMR30529016918
Aggressive Off-Road Looks & Durability
One of the best options on the market for your 2004-2021 F150 or SVT Raptor is to throw on some aggressive-looking Method Wheels and their NV design pattern are a great way to take your truck to that next level. These awesome wheels come in a bronze with a black lip finish that gives your truck an aggressive and rugged off-road look while their construction minimizes weight and provides increased overall strength. Precision-machined, these Method Race Wheels not only make your truck look awesome as a daily-driven F150 or Raptor, but also provide the strength to handle any off-road challenges that you can find off-road. High-Quality Construction with Aggressive Offset
Method's NV wheel fits right onto your truck's hub and has a great offset that allows big tires to stick out just slightly farther than stock for an aggressive look, especially with a dark paint job or other black exterior parts and accessories. This large-diameter wheel is manufactured using a low-pressure aluminum casting technique that makes it strong and durable enough for practically any application but lighter than your original factory stock wheels. Each wheel comes with a standard 6x135mm bolt pattern that allows them to fit right on to your truck's hubs without the use of wobble bolts, spacers, or other adapters. These wheels include a 5.75 backspacing that provides a great look and the ability to use big brake kits and other braking upgrades without clearance issues.
Wheel Specifications:
  • Size: 20x9"
  • Bolt Pattern: 6x135mm
  • Offset: 18mm
  • Backspace: 5.75"
  • Max Load: 2500lbs
  • Hub Bore: 94mm
Fitment: 2004-2021 Ford F150
1 - 1 of 1 Posts
