Hello all,
I have a 2011 FX2 that just rolled 100k. The only thing I have done to it is add a 4" exhaust from AE Power...everything else bone stock. I changed the plugs on it with SP-534's at 75k. Within the past month, when I put heavy load to get on highway etc. it shutters real bad and goes into limp mode. I drilled the weep hole in the inter-cooler thinking it was moisture but that did not help. I called dealership and they recommend I put new plugs and coil packs in it. They offered to do it for $800 and change. NO THANKS.
My question - can I use SP-534 plugs if I buy aftermarket MSD coil packs? Some suggest a 'one heat range colder' copper core plug and some say the SP-534's are fine at a .030 gap. Any advice? Anyone have any success or bad luck with MSD coil packs? Any input is greatly appreciated in advance. Need to fix asap...the limp mode is not fun on the highway:/
