Love it. You helped me make the right decision for sure. I use the G15 with 5" pads, the Meg's M300 with 3" pads, and a little griots one for 1" pads. I can get anywhere and everywhere. About to use them on my cousins Expedition this weekendI hope you like it the way I like mine. It does a lot of work but still gets into moderately tight curves. I have several buffers but this is my go to machine. I do however run 5” pads.
HA! Snake’s pace, you crack me up.Got some stainless and kevlar braided Raptor length brake lines and new Raptor size tie rood boots in the mail. They'll get installed somewhere in between @Blown F-150's and @snakebitten's pace...
I still need the rear end. I found and am strongly leaning towards an RPG rear frame support and bump stop kit for sale literally around the corner from me. Can't even use it until I get a Raptor axle. Then fiberglass bedsides or a Raptor takeoffbed. Good deals really screw up my proposed build order...Is this a full raptor suspension now or still need rear end?
He must be a COLD snake meandering blissfully haha. A bit ironic because he seems the type to really enjoy laying out in the sun.HA! Snake’s pace, you crack me up.
We have rearends in stock, new take offsYa I needed front spacers to clear the new upper arms until I buy some new rims. I only needed about 1/2" of spacer but I didn't want to cut my lugs so I grabbed some hubcentric spacers off of facebook. I put on the fronts and it looked even weirder with the fronts 5" wider on each side.
So now I have 2" spacers on all 4 corners
No no- SVC with Fox IFP bumps, hit me up tomorrowI still need the rear end. I found and am strongly leaning towards an RPG rear frame support and bump stop kit for sale literally around the corner from me. Can't even use it until I get a Raptor axle. Then fiberglass bedsides or a Raptor takeoffbed. Good deals really screw up my proposed build order...
Those look awfully familiar, lol.Couple updates and a couple more in the queue.
Installed new mirror puddle lights and smoked sequential mirror signals. Made a much bigger visual impact than I anticipated, very pleased with the look both with lights on and off.
07-14 F150 BrightTRAX LED Puddle Lights TRAX-STAGE3
www.stage3motorsports.com
Sequential LED Turn Signal Mirror Lamp (Pair) (Rear) For Ford F150 Raptor Expedition Lincoln Mark LT
OEM # 4L3Z13B374AA 4L3Z13B375AA For Vehicle Brands/Model: FordFord Model: F150 2004-2014Ford Model: Expedition 1997-2007Lincoln Model: Mark LT 2006-2008Interface Type: NoneVoltage: 12VItem Weight: 0.3kgeasternshoreretros.com
Smoked Sequential Side Mirror Indicator Blinker Lights (Pair) (Front) For Ford F150 and Raptor 2009-2014
Rear Markers needed for plug and play install. Can be found HERE. OEM # 9L3Z17E748BA For Vehicle Brands/Model: Ford F150 2009-2014Wattage: 5WItem Weight: 0.15Voltage: 12Veasternshoreretros.com
You know it! I go to your thread for half of my shopping list lolThose look awfully familiar, lol.
To bleed the brakes, get one of these. You can make the standard adapter work, but they also make one specific to our trucks. It works very well and makes it a super easy one person jobThis week I started to swap brake lines. Got the lines installed but still need to bleed them. Forgot my birthday was yesterday, so that and a hectic work week have slowed me down. Then the landlord comes tomorrow so I've got to catch up on some chores and messes that I've been procrastinating
Gen1 and Gen2 Ford Raptor SDHQ Built Brake Line Kit
Tired of feeling like you are stomping on a soggy muffin when you hit the brakes? Offering a solution to the problem-prone stock rubber hoses that tend to expand and stretch each time the pedal is applied, these new replacement brake hoses will provide both a firmer pedal and less pedal travel...sdhqoffroad.com
Once the lines are bled I have some new tie rod boots to install, and put my wheel spacers back on.
