Summarizing, I seem to be having 3 types of issues, possibly inter-related, not sure...
I think my next step is to swap 5# wastegate springs in and see if that gives
@Boostking any better control
Maybe take it to the dealership for a new strategy code. Then bug
@Boostking with a couple bucks to update yet again. Been dragging this guy around for almost 3 years now I think
1. Bad turbo from the beginning? WG or boost solenoids hooked up wrong?
-Excessive oil from BOV and turbo fittings
-Laggy acceleration and then a quick jump
-Only hitting 54 #/min max (likely because of tuning limits due to VCT issues)
-Warped CRP manifolds on both sides
-Logged catalytic temps of 1700*F
2. Bad phasers or something VCT related
-Intermittent cold-start phaser clacking
-Excessive noise when running cold (sounds like a valve that needs adjusted)
-Occasional clack noise when pulling into a parking spot or slow-rolling idle
-VCT actual not matching the commanded target, both intake and exhaust, especially around 5600-6000 rpm
-All 4 VCT solenoids are brand new
3. PCM/ strategy code related? Harness/ termination damage?
-Original PCM was fried by dealership, Ford refurb installed with new motor.
- 2-3 Random instances of truck dying in the middle of the road, first ~5k miles of the new motor. Hasn't happened in a long time
-VCT issues are consistently in the 5600-6000rpm range
