2012 fx4 boost cycling
885 Views 55 Replies 7 Participants Last post by  snakebitten
my 2012 fx4 is cycling boost on factory tune 15psi-7psi over and over around like 1/2 to 3/4 throttle. I put a 5star tune on it i also get the same thing but with pressures being 20-13 over and over. I have done new plugs, coils, timing, factory turbos, exhaust manifolds, all sensors. I checked for leaks and see none. It does not throw a code at all, It is getting quite annoying trying to figure out. i even drilled the 1/16 hole for condensation. I also have been reading form after form checking all and double checking with no solution. i am just at a loss and am about at witts end. I am hoping someone else has had this issue and has figured it out.
1 - 20 of 56 Posts
Waste gate solenoid?
The “spider” assembly that includes the waste gate solenoid has a whole bunch of vacuum lines that could have a leak
Reactions: 1
Wouldn’t that be seen on the boost gauge though my vacuum shows anywhere from -5 to-10 at idle and everything I read shows that’s right
Are you able to watch vacuum as your boost cycles? Curious if there is any correlation in the readings
I can do another datalog and post it
Any certain pids you want
This issue is usually tied to the PCM not being able to target the right boost level to match the torque demand. Given the age, I would 100% recommend starting with some new WG Actuators, if you don't find any damaged or cut lines running to the WG's or running to and from the WG solenoid mentioned above. The Diaphragms in the WG's fail over time.
They show out of stock, but you may be able to go to the TurboSmart version. Keep the springs to 3.5 -5psi.
The turbos came with new wg and bov and I replaced all the solenoid
But I will buy a roll of vacuum line and just replace all lines this Sunday to see if that helps stall
Verify your cracking pressure as well. You'll want a cracking pressure of 3-7psi. If you're outside of that, it will cause the symptoms you are seeing. It's roughly 2 full turns of preload on the rod.
Reactions: 1
Those symptoms sound like a boost leak. Also I recommend staying on the stock tune until you figure it out.
Did you ever remove the intercooler?
Reactions: 2
I didn’t remove the cooler but I am keeping it a factory tune
I’ll check that here in a second thanks
Reactions: 1
The drivers side is like 6psi and the passenger side is like 7psi
Reactions: 1
If it was boost leak wouldn’t it happen all the time not just at certain throttle positions?
I plugged in my scan too and did a scan of all modules I seen in the pcm there is a stored code for wastegate solenoid a high. Which solenoid is a? The top or the driver or the passenger side? And would I have gotten that by unplugging it up top to check voltage while key on engine off?
Cleared the codes drive a few times never came back tried a kam reset to no luck Matt buy some new vacuum lines tomorrow and start replacing. Any preference on vacuum lines for booster engines?
1 - 20 of 56 Posts
