1 - 3 of 3 Posts
Need some assistance on sourcing the vac/boost signal. 2010-12 have a vacuum line that runs off the rear passenger side of the intake. The line doesn't exist on the 2013. If anyone has installed a Mechanical boost gauge on a 2013 please let me know how you did it.
just did.
Take the engine cover off and find the hoses under there.(two that run over the engine on the drivers side) Tap into one of those two hoses. As for the power..I tapped into the 4x4 wire cluster.
Or if your lucky enough, theres a nipple right behind the throttle body with a rubber cap on it. Take cap off and use that for the source, works perfect on my '13
1 - 3 of 3 Posts
