2013 F150, my brake warning light started coming on in a strange way. It would flicker like a bad connection then slowly just stay on.(about 10 mins of driving) Sometimes in the wet, it would flicker while driving. I have replaced the master and the low fluid switch tests fine. The switch at the foot brake pedal also bench tested fine and when I take the park brake off the beeper stops (tell tale sign the switch is good) My problem is the brake light on the dash is on all the time. Seems like a ground issue or wiring issue as I don't think there are any other areas in the circuit to fail. Maybe I'm missing something. Hoping someone may have had this issue and found a solution.
Thanks Mike
Thanks Mike
