1 - 9 of 9 Posts
I noticed my reservoir was empty when I changed my air filter the other week. So I topped it off... it's gone down already... so I'm thinking I've got a leak somewhere.
I do not have anything leaking to the point of a puddle or any obvious signs.
From what I'm reading on here, there are a couple places it seems to leak from.
1. Reservoir joint
2. Fitting on turbos
3. T-fitting
Anywhere else I can check? I looked at the fittings under the reservoir and don't see anything there... like I said no puddles either. Hoping it's not the turbo fitting... looks like it could be a bit of work pulling the turbos.
TIA
Could also be a blown head gasket and you don't see a puddle because your motor is trying to combust the liquid leaking in there.
Also check your oil. I think it's possible that the oil cooler can leak coolant inside it.
Check the underside of the elbow at the reservoir, that's where the drip propagates from. It will end up on the d/s frame rail as well. Stick your hand or a paper towel under there and see if it comes back greasy/coolanty. Super common and pegasus racing makes a kit that solves the problem 100%.
Found the kit here:
Pegasus Kit on Amazon
Will check it more thoroughly as it's been mentioned a few times.. the reservoir elbow that is. As I understand it, there's an o-ring in there that goes bad... the Pegasus would certainly resolve that... forever. Fingers crossed it really is leaking and that's all it is. Simple fix if so!
Found the kit here:
Hey @tri4autism,
Did you find your leak? If it was the quick-disconnect at the bottom of the tank, you might want to check out our replacement expansion tank. Our tank replaces that QD and a portion of the stock line with a proper barbed fitting and silicone hose. The QD fitting on the tank isn't designed to hold a hose with a worm-gear clamp and we've seen a few continue to leak with that method.
Feel free to let me know if you have any questions or if we can help in any other way!
-Steve
When installed properly that pegasus kit is bang on. It is a little janky in construction, but it does work.
"janky in construction" that is a good way to describe the Pegasus kit. I installed mine about a year ago, and you definitely know it's not factory, but like you said it gets the job done
Discussion Starter #9
Bad news... I think, appears to be both turbos leaking at their coolant connections... not sure I want to tackle this one myself.
1 - 9 of 9 Posts
