1 - 13 of 13 Posts
It has a clean carfax with no incidents. The Bumper is chrome. The dash switch doesn't pull out like it even had fog lights..
I was thinking about looking into the fuses and see what they say.
Edit: It's actually not a carfax I guess. It's an AutoCheck from experian
Originally Posted by Vozaday
Could be a Canadian truck. Looks like fog lights were an option for xlt's. http://cdn.dealereprocess.com/cdn/br.../2013-f150.pdf
Click this bar to view the full image.
Must be the case. I've had a hunch that it was anyways. The speedometer is lined up weird, it has a block heater, and daytime running lights. I've never really looked into much to check tho
Would the badges say XTR?
Discussion Starter #8
Why not decode the VIN to show production location and oem equipment at build?
Discussion Starter #11
Vin says Dearborn, Michigan. It does have a Canadian sticker.
Here's a pic of the front end. You'll have to excuse the dirt, it's been raining here.
Seen a few of these at rental companies. I think, but not sure that they may be fleet order XLT's. All XLT's I see at dealer's lots and 99% on the road have fog lamps.
Punch in your vin here for detailed info on your truck. https://www.etis.ford.com/vehicleRegSelector.do
Looks like a fleet. But you can easily add fog lights to your front end, wayy better lights than stock too. Or put a light bar in front of your radiator, behind the grill - hoping to do that myself eventually.
1 - 13 of 13 Posts
