Hello everyone, I’m new here and hope I’m posting this correctly.
My truck went into the no crank, no start condition in the morning after a passenger tripped the theft alarm. I cancelled it right after with the only working key which the truck calls MyKey. I didn’t try to start it til the next day. There is power to all accessories and such, I’ve tried to start it in N without success. I checked fuses and refitted them. I reseated the relays and swapped #62(wiper motor) into the following locations; #2 starter, #7 run/start, #8 fuel pump, #10 power train control module. Swapped fuses #27 fuel pump relay power to #76 power train cont mod. Fuses were all good. I checked inside panel for fit too. There are two distinct clicks after key is put in start position from the right pass side. No code reader. Advice, next best step, hints please. Thank you. Brad
