I ordered a blue 2014 FX2 eco to be here the begining of august because I have to modifiely it to replace my current 2014 dodge ram,as the custom seat and lift for the wheelchair has not been working out to well....I needed everything done by the end of august or begining of sept 2014...The dealer Call and told me it would be here 8/15 then said it will be even later by 2 months, I have purchased a ranch ,and the house will be ready in Sept or October..It will be livable the end of august or begining of sept..My son starts school the end of Aug,so I needed to be ready to move then.. I only ordered one because there was not one matching truck in the whole state.So I search again 2 months later and there was only one truck with the same specs i wanted in the whole so I got lucky..It was not blue,but a Black supercab Fx2 eco with appearance package ..So i had them do a dealer trade for it,although i didnt want the moon-roof or the nav,but oh well..being i got 9k off a extra 1k for being a disabled vet..I jumped sort of,lol...it looks better in black anyway !!
I am havin extensive metal works lower it with air bags so the frame will sit on the ground,so i can get in with my wheelchair..they are removing all the stock suspension,adding custom made tubed control arms,new fender wells,notching the frame,cuting the center out of the bed for the rear diff to come up into the middle of it,adding 6 piston calipers,and big rotors,Semi truck ford airbags,and a four link in the rear..there is a bunch of other stuff as well..
it will have hand controls,and a bunch of extra Hp, I am wanting 500rwhp,and 600-650rwtq..as far as rims i like the 20 inch stock black ones,so i may keep them or order black deep dish in the rear...
AS far as anything else ,its got the sony stereo in it,but i may add a couple hundred extra watts,and change speakers...
the doors are going to be widen,and open up past 90 degrees,and removing the running boards..
I am going to tint the windows to 5%,legal because i have a doctors note,due to being blind in one eye..
I have added the ford search system App in case its stolen,and can be found in under 22 mins,so they say..
I pretty much has every option on it..
I am going to ad some bright lights to go with the stock HID
I am going to add inside lights
I am going to add GT500 hood
Every decent performance part I can find that I can also see what it makes without a tune, alone,and then what it makes combined in a package with other parts that balance each other together best..
I am going to add meth,mode the turbo's,increase the fuel supply,with a little spray.
Then maybe I will stroke it later down the road..Because from what i read the motor is pretty much rock solid as it is.
The reason I am lowering it so much ,is because I am a disabled vet,and wheelchair bound,normally before that happened in my life I would either leave it stock,improve the handling,or jack it up,but i have never bagged it down to the ground before...
I am
The rear end housing is going to be shorted 2 inches on each side,adding stronger axles,a better 3.55 rear gear instead of the 3.15 that came with it..
Here are some pictures from the dealer I found it at in San Antonio...
I am
