2014 FX4...Slowly making progress
150393 Views 2266 Replies 73 Participants Last post by  Blown F-150
5
I figured it was time to get all my additions to the truck listed out and tracked. I have it all documented on a Detailing site, but obviously doesn't get a whole lot of views.
Current upgrade list
Exterior
Raptor Wheels and 285/70/17 Ridge Grapplers (winters)
Raptor Running Boards
MX GrillCraft Upper and Lower Grills
OEM 2016 Sport 20" with OEM Hankook's (Summers) - SOLD
Expel film on front Bumper
Spray in Box liner
Morimoto XB Fogs
Removed lower air dam
Access "Vanish" tonneau cover
AVS in-channel visors
AVS bug deflector
AS 2" level
Hellwig sway bar
Pro-Comp AAL
Fox 2.0 Rear shocks
Rear wheel well liners
EZ Tail Gate assist
Pop a lock tail gate lock
LED bed lights
Recon 3rd Brake light
Recon Tail lights
Recon LED puddle lights
ANZO LED marker lights
Flat black FX4 Bed decals
Custom flat black "EcoBoost" decals
Painted F150 emblems
Painted FORD emblems
50% ceramic window tint on the from windows
42" LED Light bar - Removed for FR CAC
12v/5v Power outlet in box of the truck
Interior
Raptor Steering Wheel
WeatherTech Digital Fit Mats
3M protective film on the door sills
Kicker Subgate upgraded sub
DRW-650 2-channel dash cam
Back seat access mod
Custom Hydro dipped door panel inserts and stereo surround
Full LED interior light conversion
Custom overhead light switch panel
Performance
SCT Xcal4 Tuner with MPT tunes (87 perf/chill, 87 tow/street, 91 Perf/street, 91PRX, 93PRX)
Full Race FMIC in Black
Tial BOV
AFE Stage 2 CAI
3" MBRP Cat-Back Exhaust (added Magnaflow 6" round muffler)
GT Turbos
Ported Manifolds
SPD Turbo adapters
I started out with a new 2014 FX4 Screw luxury pack in Blue flame. 7200# GVW, 3:55's. Pretty much all options other than Max tow and Apperance pack. Built in November of 2014 and I bought it March of 2015.
Bought the truck from family that work at a dealer, great deal as I was able to get it for less than used. Downside is it was 600miles away. Thankfully, my Uncle delivered it for me.
I had them put 3M on the bumper and do a Spray in liner. They did a great job with both.
Window Sticker
Day I got it.
I already had a 2" AS level for it that I put in a couple of days later
Before
After
The kit came with a 3" rear block, but I figured it would put too much rake back in for my taste.
on level ground, it measures perfectly level. I would have liked a bit of rake, but I address that later on...much later.
See less See more
Reactions: 1
1981 - 2000 of 2267 Posts
More googling makes it apparent your scale is inverse from ours. Converted to metric...
97kph > 10.7 L/100km, up(down?) to 9.8
105kph > 11.8-
113kph > 11.8
121kph > 13.1
129kph > 14.7
Seem about right?
Yup, you’re bang on. Mine MPGs are never that good overall though. By the time I get to the end of a tank, I’m usually around 11-14mpg.
It’s truly a “Jekyll & Hyde” truck when it comes to MPGs
The truck sees a lot of short trips these days and I drive it fairly hard to get it warm when I can. Weekends are usually spent flogging it on dirt roads shuttling mountain bikes.
Reactions: 1
It’s getting to be new tire time. I think I’m pretty set on the Toyo AT 3’s. The other main competitor was Nitto Recon Grapplers, I really like them, but they don’t have the winter rating that drops my insurance, lol.
Any thoughts or input? I’m thinking of staying with the same or very similar size to my 305/65/18’s that are on it now.
Reactions: 1
I like a narrower tire in winter. I feel like traction is better.
I totally agree, however it’s gotta be a “do all” tire, so it has to look sharp too
Reactions: 1
I just put the Toyo AT3's in a 35x12.5r17 on my truck, no feedback yet. I have a couple hundred miles of road trip this weekend and some light offroading for dove hunting. Curious how they'll do in the Arizona sand.
The sidewalls certainly look beefier than the Nitto TerraGrappler G2's I had before.
Reactions: 1
Let me know how they work out!
Well the Toyo AT3's worked out just fine. I did get "stuck" the very first night after parking in a soft sandy spot. Aired the tires from ~40psi (or whatever the tire shop filled them to) down to 25psi. Never any issues for the rest of the weekend, cruised around dirt, sand, and pavement without a hiccup. Aired back up at the gas station before hitting the road back home.
I plan to setup my own air compressor soon. I have an Expedition airbag suspension compressor that I'm hoping to make useful
Reactions: 3
That’s great, thanks for the feedback! The more I look into them, the more I like them.
After getting terrible fuel mileage going up North to pick up the Quad, I decided it was worth while to try and put regular IWEs back in the truck. I swapped out the deletes with Dorman brand (same “warn” supplier as OEM) last night. Only took about 45 minutes to do both sides.
Pulling the empty flat deck with the deletes, netted me about 11.1mpg. I’m pulling the same trailer again today, so I’ll compare and see what it does now.
See less See more
Reactions: 3
Well, got the results I was hoping for.
On the same stretch of road with the trailer, it got 13.2mpg at 80mph.
Even without resetting the gauge, the truck went up to 17.1 mpg on the trip back without the trailer connected.
So I guess I’ll stick with the OEM IWEs and just make myself a valve to “lock” them if I want to for a drag race or something.
Reactions: 3
Getting a little excited, this spring/summer should be pretty fun! Some pretty significant upgrades on the way. Just have to hammer out a couple details around fuel.
Reactions: 2
After spending WAY too much time looking at tires and the size/cost/availability options, I'm going back to a set of 285/70/18 Ridge Grapplers. I wanted the new Recon Grapplers, but they are only available in 20" for now.
Reactions: 5
Heck ya lots of rubber (y)
I think so, also lot's of tread depth, Ok on the weight side of things, good load rating and I'm going to just do dedicated winters next year.
Reactions: 1
Niiiice.
I’m surprise how impressed I’ve been with my ridge Grapplers, I wasn’t expecting to be this impressed even though I knew they would be great. Seriously thinking about the Mickey Thompson Baja boss next just for something different though, that is if I stay with 35s since they don’t have a 37/18 yet
Niiiice.
I had them before and really liked them. Moved to the KO2 mainly for the winter rating and they were a solid deal. I like the Mickey’s and have run their older AT on a previous truck, but they wore terribly for me. I’m sure the newer ones aren’t the same though.
Getting a few small things done on the trucks "refresh". Full Race Intake, EPP inlet tubes, Tow hook mounts and my Sport 20's all taken to the Power coater.
Next up is peeling off the original PPF, so see what kind of damage lies underneath. The game plan is to get the Raptor boards re-coated. At the same time, I'll get the very bottom of the body PTM bed lined and possibly the front bumper if it's in rough shape under the PPF.
Reactions: 2
Ridge Grapplers on backorder, so who knows when I'll see them.
Reactions: 2
I bet you could get some Made in USA Coopers :p
  • Haha
Reactions: 2
