181 - 200 of 2,443 Posts
I bought this https://www.amazon.com/s/?ie=UTF8&k...cmdl=&hvlocint=&hvlocphy=9026231&hvtargid=kwd-3588025425&ref=pd_sl_9giegw8ai3_e and deleted the resonator. I had a muffler shop install a 3" flange at the y pipe, replace the stock 2.5" flex with 3" and run all 3" pipe. Basically every piece of pipe and fitting from the Y pipe to the back of the muffler is still there as it was from the factory just in 3". I just deleted the resonator. It isn't much louder than stock.
Did the exact same thing except deleted the muffler and kept the resonator contrary to most things I have read. I absolutely love the sound. I highly recommend playing around with combinations of some 3" and the stock components. I have tried offroad downpipes mated to the stock catback. I've tried offroad downpipes mated to full 3" all the way back deleting muffler and res (way too obnoxious for me). So I put the muffler back on. Wasn't satisfied so I pulled it back off and put only the resonator on. I think it's perfect for what I was after.
Also, to the OP I have the exact same 3-4 upshift whine/slip noise you have. I haven't heard of others having this problem before could you by chance point me in the right direction to research that TSB? Or tell me what kind of additive to try? Thanks!
Discussion starter · #183 ·
Totally forgot to post some pics, ha.
All well, I'll post some up when they are installed.
Just ordered up a set of RCI skid plates in aluminum. They'll just be raw as I didn't want to pony up the cash for a coating that will be scrapped off anyway.
Kicking around the idea of a winch again. I want to add one, but think it wouldn't be used very much. I think I need to get the Exhaust sorted out first, still thinking on that...
Not much else I want to do other than minor cosmetic mods, so it will be starting to get back into save mode. Then I'll decide on a payment free truck with a RMB motor or a new Raptor. Fun times!
Discussion starter · #184 ·
So sorry! I missed your question on the 3-4 shifting noise. You just need to head to your dealer and buy the "XL-16". the TSB is 14-0100. It's the same additive they used for a few different tranny issues.
Here is a link to the TSB
https://ford.oemdtc.com/TSB/14-0100.pdf
I had to add the full amount of the syringe to stop mine from making the noise. I was told to start with 10ml, drive it for a week and then see if you need more.
Could you enlighten @Blown F-150 of the part number for that drain valve. I tried looking it up through them and it says "Sorry, it seems like Ford used a yellow proprietary plug on this one :(. You'll most likely only be able to use that plug." which is incorrect because I have changed the oil multiple times and its a 15mm bolt
Edit: Think I found it by searching 2014 instead of 2016 http://www.fumotooildrainvalve.com/f107sx.html
Discussion starter · #191 ·
Yeah, they changed the plug when they went to the plastic pans in the 15+ Ecos. I prefer the Fumoto as it directs the flow straight down and you can throw a hose on it if you like. I now have limited space with the skid plate, so this made sense. On a side note, I was worried about getting at the front filter with the skid plate, but can reach it no problem.
Now to get these suckers on
And as a side note, Full Race resonated Cat-Back ordered.
How much did the coil overs and plates cost shipped up here to canuckistan? Or did you cross border shop em?
Discussion starter · #193 ·
I’ll shoot you a PM with the details. Coil-overs were through EBay and I got them so cheap that the shipping and brokerage fees were palatable. The plates were pricey though and since they shipped UPS, I had my bottle of lube ready for when the big brown truck showed up. Their brokerage costs are stupid expensive.
I’m shipping the cat-back to a mail service on the US side and will pick up this upcoming week. Saved over $300 CDN in shipping and brokerage doing it this way.
Discussion starter · #194 · (Edited)
Mod List re-cap (Can't edit old posts apparently)
Current upgrade list
Exterior
RCI Aluminum Skid Plates
Raptor Wheels and 285/70/17 Ridge Grapplers
Raptor Running Boards
MX GrillCraft Upper and Lower Grills
Expel film on front Bumper
Spray in Box liner
Morimoto XB Fogs
Removed lower air dam
Access "Vanish" tonneau cover
AVS in-channel visors
AVS bug deflector
AS 2" level
Hellwig sway bar
Pro-Comp AAL
Fox 2.0 Rear shocks
Rear wheel well liners
EZ Tail Gate assist
Pop a lock tail gate lock
LED bed lights
Recon 3rd Brake light
Recon Tail lights
Recon LED puddle lights
ANZO LED marker lights
Flat black FX4 Bed decals
Custom flat black "EcoBoost" decals
Painted F150 emblems
Painted FORD emblems
50% ceramic window tint on the from windows
12v/5v Power outlet in box of the truck
Fumoto Valve
Interior
Raptor Steering Wheel
WeatherTech Digital Fit Mats
3M protective film on the door sills
Kicker Subgate upgraded sub
DRW-650 2-channel dash cam
Back seat access mod
Custom Hydro dipped door panel inserts and stereo surround
Full LED interior light conversion
Custom overhead light switch panel
CravenSpeed Dead Pedal
Performance
SCT Xcal4 Tuner with MPT tunes (87 perf/chill, 87 tow/street, 91 Perf/street, 91PRX, 93PRX)
Full Race FMIC in Black
Tial BOV
AFE Stage 2 CAI
Full Race GT Turbos
Ported/Ceramic Coated OEM Manifolds
SPD Turbo adapters
Full Race Catted and Ceramic Coated DP's
Full Race Resonated Cat-Back
To be installed
Fox 2.0 Coil Overs
X2O Smittybilt 10k winch
1010 Rough Country hidden winch mount
Kevlar Brake lines
Yea but they didn't go to plastic on the 15+ eco's because my brother owns a 2015 3.5 ecoboost, and I own a 2016 3.5 ecoboost and both are metal pans and bolt. Maybe they did in the 2.7? I don't know, but I know for fact they didn't on the 3.5's.
Discussion starter · #196 ·
They did on the 2.7’s only.
I’m not sure about the gen2 3.5’s
Discussion starter · #197 ·
Full Race Cat-back has landed state-side. I will go and pick it up this weekend. I took Monday off so I may get a chance to install then.
Fingers crossed, I don't have to swap out the muffler for a Magnaflow fatty.
FR cat back is on. As usual, very nicely put together with quality pieces. Installed very easy. Tip is nicely tucked and shouldn’t impede while messing off-road.
I’ll be interested in reading your thoughts on the way it sounds. I’ve been looking at these for a while.
Discussion starter · #200 ·
I’ll get some sound clips and not just a start up. I’m very happy with the sound and glad I got the resonator. Very mellow when cruising around and has a decent bark when winding it up. I think it would be the perfect sound level with the stock DP’s. Great whistle with the FR DPs.
