261 - 280 of 2,443 Posts
Discussion starter · #261 ·
I was able to get three of the bed panels installed and the two rear seat latches. I have to modify the one panel so I can still access the PowerPoint. The panels aren’t as big as I had pictured in my head, so we’ll see how much of my gear actually gets mounted to them.
Discussion starter · #262 ·
Bed rack system to mount to the rails showed up today. Took the day off tomorrow, so hope to get that installed. I'll also try to get the one bed panel modified and installed. Then I'll start mocking up the tool locations so I can get as much mounted on the panels as possible.
If I took a day off when new parts showed up... I'd lose my job.
Wait, I'm self-employed! ;)
Discussion starter · #264 ·
Ha, but that's just because you have A LOT of new parts showing up.
I'm pretty fortunate and get 6 weeks a year vacay, plus I often bank a day here and there due to business travel.
I took Monday and Friday off next week too so I can get stuff done on the truck, lol.
Discussion starter · #265 ·
I was able to wrap up the install today. It was a royal pain to get the plastic bed rail caps off! I also had to remove the Tonnaeu, which is pretty easy.
Drilled, painted (to help prevent rust) and then installed the nut rivets. Then it was just popping the covers back on and bolting the tracks down.
Currently running without the cross bars.
Also had lots of help today
Discussion starter · #266 ·
I also was able to get the Starky “Raptor” front lights in. Great kit that’s very well made. I did end up cutting back the ground wire to route it better. Looks great and it may not look like it in the pic, but the colour is bang on.
Discussion starter · #267 ·
Waiting on the upper a-arms, but took Friday off. I'm hoping it warms up a bit as I would like to get the paint clayed, polished and sealed on Friday.
Discussion starter · #268 ·
I was able to get the truck washed, clayed and “coated”. Pretty happy with the result, but it will need some paint correction when time allows.
It started to rain, so no good after pics.
Discussion starter · #269 ·
I was also able to get the one panel “modified and installed. Not super happy with the cuts, but I’ll probably file it down a bit and then take in to re-powder coat.
Looks a lot better than mine for sure
Your obviously a perfectionist - I'd be way more than happy if one of my DIY cuts looked that good.
Discussion starter · #273 · (Edited)
Mod List Updated (Can't edit old posts)
Current upgrade list
Exterior
RCI Aluminum Skid Plates
Raptor Wheels and 285/70/17 Ridge Grapplers
Raptor Running Boards
MX GrillCraft Grill
Expel film on front Bumper
Spray in Box liner
Morimoto XB Fogs
Removed lower air dam
Access "Vanish" tonneau cover
AVS in-channel visors
AVS bug deflector
AS 2" level
Hellwig sway bar
Pro-Comp AAL
Fox 2.0 Rear shocks
Rear wheel well liners
EZ Tail Gate assist
Pop a lock tail gate lock
LED bed lights
Recon 3rd Brake light
Recon Tail lights
Recon LED puddle lights
ANZO LED marker lights
Flat black FX4 Bed decals
Custom flat black "EcoBoost" decals
Painted F150 emblems
Painted FORD emblems
50% ceramic window tint on the from windows
12v/5v Power outlet in box of the truck
Fumoto Valve
Rough Country Hidden 1010 winch mount
SmittyBilt 10k "X20" Winch
BuiltRightIndustries Bed rack/panel system
Yakima Bed Rack system (Mounted to Bed rails)
Fox 2.5 Coil-overs with DCS
PowerStop Rotors with Raybestos hybrid pads
Interior
Raptor Steering Wheel
WeatherTech Digital Fit Mats
3M protective film on the door sills
Kicker Subgate upgraded sub
DRW-650 2-channel dash cam
Custom Hydro dipped door panel inserts and stereo surround
Full LED interior light conversion
Custom overhead light switch panel
CravenSpeed Dead Pedal
BuiltRightIndustries - Rear Seat Latch
Performance
SCT Xcal4 Tuner with MPT tunes (87 perf/chill, 87 tow/street, 91 Perf/street, 91PRX, 93PRX)
Full Race FMIC in Black
Tial BOV
AFE Stage 2 CAI
Full Race GT Turbos
Ported/Ceramic Coated OEM Manifolds
SPD Turbo adapters
Full Race Catted and Ceramic Coated DP's
Full Race Resonated Cat-Back
To be installed
Kevlar Brake lines
Exterior
MX GrillCraft Grill
Spray in Box liner
Morimoto XB Fogs
AVS bug deflector
AS 2" level
Hellwig sway bar
Pro-Comp AAL
Fox 2.0 Rear shocks
EZ Tail Gate assist
LED bed lights
Recon Tail lights
Fumoto Valve
Interior
Performance
Tial BOV
AFE Stage 2 CAI
Full Race GT Turbos
SPD Turbo adapters
To be installed
Fox 2.0 Coil Overs
Kevlar Brake lines
PowerStop Rotors
Not sure why you can't edit old posts...but I like it that you can't. LOL
It keeps me from having to look through the 28 current pages to find your mod list. :) :) :)
Keep up the build, Dude. I enjoy following it.
Discussion starter · #275 ·
Not sure, but it seems like once they get to a certain age, the "edit" option disappears.
Thanks for the compliments, this truck has been awesome and fun to work on. I'm glad folks like following along!
So tempted to order the GrillCraft grill. TRex also makes one that looks good, but they’re proud of it! Haha. It’s also very expensive for it to be shipped to Alaska - if any vendor will even ship them...
Think you might be able to show a **** if your overhead switch panel? Just curious. Unless it’s one made by KustomFX in the other F150 Forum. Haha.
Your truck has been neat to follow and you’ve done many of the upgrades I’d like to do. Thank you for sharing!
Sent from my iPhone 7 using Tapatalk Pro
Discussion starter · #277 ·
Thanks you!
Yup, it’s the Kustom FX one.
